i2c problem win stm32F412
Posted: Wed Aug 26, 2020 6:27 pm
I'm stuck with a problem with i2c, it seems the chibios 20.3.1 is not producing any signal from i2c1 (pin PB7 and PB8). They are configured as: alternate(4), high speed, opendrain.
But every attempt give me -2 as status and i2cGetErrors is 4
What it bother me is that if I use the CubeMxIDE with STM primitives, I've got both the signals on the pin and the correct answer from the eeprom I'm trying to access
The other periphericals enabled in chconf is the USART6 and USB_OTG (and they works fine). The clock is configured exactly as CubeMx.
I have used few years ago chibios 3 for reading from i2c with an STM32F429 and the settings for the pin / initialization of the driver / writing are almost the same. Could it be another settings I'm not aware of for this board? I've already searched inside the forum for some idea (I've disabled most of the other peripherical to avoid dma conflict, check for correct pin assignment, ecc)
I would rather not to switch to CubeMxIde because I find Chibios more easy to work with.
Any help / suggestion would be very appreciate.
ps: if the pin is wrongly configured, is there any means to check them at runtime (like a variable where I can check the bitmask for the correctness)?
Enrico
static const I2CConfig i2ccfg = {
OPMODE_I2C,
400000,
FAST_DUTY_CYCLE_2,
static THD_FUNCTION(reader_thread, arg) {
chRegSetThreadName("reader");
(void)arg;
uint8_t txbuf[2];
uint8_t rxbuf[2];
txbuf[0] = 0x00;
txbuf[1] = 0x00;
chThdSleepMilliseconds(1000);
chprintf(chout, "entrato lettura\r\n");
sysinterval_t tmo = TIME_MS2I(100);
i2caddr_t addr = 0xA1;
i2cStart(&I2CD1,&i2ccfg);
chprintf(chout, "partito driver i2c: %d\r\n",I2CD1.state);
while(true) {
chprintf(chout, "invio richiesta\r\n");
chThdSleepMilliseconds(100);
i2cAcquireBus(&I2CD1);
msg_t status = i2cMasterTransmit(&I2CD1, addr, txbuf, 1, rxbuf, 0);
i2cReleaseBus(&I2CD1);
chprintf(chout, "risultato: %d [%d]\r\n", status, i2cGetErrors(&I2CD1));
uint8_t data[10];
char buff[64];
/* Infinite loop */
for(;;)
HAL_UART_Transmit(&huart6, "i2cTest\r\n", strlen("i2cTest\r\n"),10);
data[0] = 0xFA;
if (HAL_I2C_Master_Transmit(&hi2c1, 0xA0, data, 1, HAL_MAX_DELAY) == HAL_OK) {
for(int i = 0; i < 6; i+=1) {
if( HAL_I2C_Master_Receive(&hi2c1, 0xA1, &data[i], 1, HAL_MAX_DELAY) == HAL_OK) {
} else {
HAL_UART_Transmit(&huart6, "receive fails\r\n", strlen("receive fails\r\n"),10);
sprintf(buff,"%x %x %x %x %x %x\n\r", data[0], data[1], data[2], data[3], data[4], data[5]);
HAL_UART_Transmit(&huart6, buff, strlen(buff),10);
} else {
HAL_UART_Transmit(&huart6, "transmit fails\r\n", strlen("transmit fails\r\n"),10);
osDelay(1000);
Enrico
