STM32F767zi UART Auto Baud Rate
Posted: Fri Nov 06, 2020 10:46 pm
by tsm
Hello.
Does chibios support automatic detection of baud rate on a UART? I've trying to find in its API and didn't see anything. From stm's reference manual I think I understand which registers I'm supposed to manipulate but not when should I do it.
Should I set them before/after the call to sdStart or should I set instead the cr2 field in the configuration (SerialConfig) passed to the function?
Thank you!
Re: STM32F767zi UART Auto Baud Rate
Posted: Sat Nov 07, 2020 6:46 am
The current drivers do not support the feature, you may try to do it after sdStart() when the clocks are already enabled.
Posted: Sun Nov 08, 2020 10:59 pm
by tsm
Thank you I'll try. Just wondering if, after the initial connection, the device I'm connected to changes baud rate do I need to call sdStop and then sdStart again?
Posted: Mon Nov 09, 2020 8:52 am
No, you need to do that after sdStart(), stopping would undo the operation.
