the current LLD implementation for the STM32F4 family does not support the I2S PLL on the STM32F411xC/E (and presumably others).
- ChibiOS version
20.3.2 (as of the tag ver20.3.2 on the github mirror)
- Compiler
gcc version 10.2.0 (Arch Repository)
- Platform and board
STM32F411VET6 on the STM32F411-DISCO (*not* STM32F4-DISCO)
- Natur of the problem
The STM32F411xC/E series controller (and presumably others) have a different configuration than implemented in the I2S hal, which I assume to be tailored to another STM32F4 series (e.g. [2]?).
Some differences as compared to the RCC_I2SPLLCFGR setup (os/hal/ports/STM32/STM32F4xx/hal_lld.c:238):
- The 411 series features a dedicated input divider M for the I2S PLL,
- it lacks the output divider Q, and
- probably many more,
see [1, p. 93/844].
- Failure mode
The controller does not start up, as it waits for the I2S pll which is configured for the wrong controller.
Thanks in advance!
Best regards
Tim
References:
[1] ST RM0383 Reference manual: STM32F411xC/E advanced Arm®-based 32-bit MCUs
[2] ST RM0090 Reference manual: STM32F405/415, STM32F407/417, STM32F427/437 and STM32F429/439 advanced Arm®-based 32-bit MCUs
STM32F411xC/E: Wrong entries in PLLI2SCFGR
WowSuchName
- Has thanked: 3 times
- Been thanked: 3 times
Re: STM32F411xC/E: Wrong entries in PLLI2SCFGR
Leaving a note here.
This requires a separate clock tree "type", closest one is F413, which has the separated M divider also. F413 has a lot of extra dividers and muxes but the common part looks equal, this new header could be obtained by stripping the F413 one of extra settings.
