ChibiOS-Contrib USB_MSD testhal example crashes Topic is solved
piers
Been thanked: 15 times
Post by piers »
I'm building a (open source) bootloader using the USB MSD mass storage device driver from ChibiOS-Contrib.
However the MSD driver crashes when connecting to a MacOS or Windows machine. This happens both in the STM32F4 and the STM32H7 example (ChibiOS-Contrib/testhal/STM32/STM32F4xx/USB_MSD and ChibiOS-Contrib/testhal/STM32/STM32H7xx/USB_MSD).
The USB driver crashes in the EP0 setup because it's already transmitting:
#1  0x08000f2a in usbStartTransmitI (usbp=0x800f6e8 <__func__.9137>, usbp@entry=0x2000d408 <USBD1>, ep=ep@entry=0 '\000', buf=0x800f734 <active_status> "", n=2) at ../../../../../ChibiOS/os/hal/src/hal_usb.c:498
498     osalDbgAssert(!usbGetTransmitStatusI(usbp, ep), "already transmitting");
Backtrace:
#0  chSysHalt (reason=reason@entry=0x800f6e8 <__func__.9137> "usbStartTransmitI") at ../../../../../ChibiOS/os/rt/src/chsys.c:205
#2  0x080011c2 in _usb_ep0setup (usbp=0x2000d408 <USBD1>, ep=<optimized out>) at ../../../../../ChibiOS/os/hal/src/hal_usb.c:834
#3  0x080024b2 in otg_epout_handler (ep=ep@entry=0 '\000', usbp=0x2000d408 <USBD1>) at ../../../../../ChibiOS/os/hal/ports/STM32/LLD/OTGv1/hal_usb_lld.c:427
#4  0x080027ca in usb_lld_serve_interrupt (usbp=0x2000d408 <USBD1>) at ../../../../../ChibiOS/os/hal/ports/STM32/LLD/OTGv1/hal_usb_lld.c:611
#5  Vector14C () at ../../../../../ChibiOS/os/hal/ports/STM32/LLD/OTGv1/hal_usb_lld.c:685
#6  <signal handler called>
#7  0x55555554 in ?? ()
My own project (on STM32H7) crashes in a similar way in EP0, but because it's already receiving:
#1  0x08001d86 in usbStartReceiveI (usbp=0x24000448 <USBD1>, ep=0 '\000', buf=0x0, n=0) at ./ChibiOS/os/hal/src/hal_usb.c:459
459     osalDbgAssert(!usbGetReceiveStatusI(usbp, ep), "already receiving");
Backtrace:
#0  0x08005224 in chSysHalt (reason=0x8009910 <__func__.10090> "usbStartReceiveI") at ./ChibiOS/os/rt/src/chsys.c:198
#2  0x0800241e in _usb_ep0in (usbp=0x24000448 <USBD1>, ep=0 '\000') at ./ChibiOS/os/hal/src/hal_usb.c:909
#3  0x08003a76 in otg_epin_handler (usbp=0x24000448 <USBD1>, ep=0 '\000') at ./ChibiOS/os/hal/ports/STM32/LLD/OTGv1/hal_usb_lld.c:399
#4  0x0800403e in usb_lld_serve_interrupt (usbp=0x24000448 <USBD1>) at ./ChibiOS/os/hal/ports/STM32/LLD/OTGv1/hal_usb_lld.c:641
#5  0x080040f2 in Vector1D4 () at ./ChibiOS/os/hal/ports/STM32/LLD/OTGv1/hal_usb_lld.c:685
With linux the MSD driver does work, only 'sudo lsusb -v -d 0483:5740' gives errors for the string descriptors and gives the following errors:
can't get device qualifier: Resource temporarily unavailable
can't get debug descriptor: Resource temporarily unavailable
cannot read device status, Resource temporarily unavailable (11)
I'm using gcc version 9.2.1 20191025 (release) [ARM/arm-9-branch revision 277599] (15:9-2019-q4-0ubuntu1)
Any ideas what might be wrong?
Re: ChibiOS-Contrib USB_MSD testhal example crashes
Those assertions are triggered if the MSD driver tries to do something in the wrong moment, see that "already transmitting", not sure about the reason. It is possible that the code is very old and some change broke it.
piers
Post by piers »
Thanks for your quick answer. To me it seems that the EP0 code is all handled in ChibiOS, in hal_usb.c. So I don't understand how the MSD code (which uses EP1) could cause an EP0 related crash? Any ideas?
The EP0 state machines calls handlers that are part of upper layers that handle protocol messages, it is possible there is a problem in those handlers.
piers
Post by piers »
Ah, I see. The problem probably is in msd_request_hook then. If I comment that out is usbcfg.c it doesn't crash, I'll look into that further.
lsusb still gives errors for the device qualifier and debug qualifier. I'm not sure if that can be a problem, but it seems nice to not have errors. Any ideas on how to prevent those errors?
piers
Post by piers »
Ok, it is fixed in ChibiOS-Contrib now, I reimplemented the msd_request_hook function, though the default reaction without custom request handler seems valid also. Stalling on get_max_lun at least. The Bulk-Only Mass Storage Reset is not commonly used apparently, so I'm not sure about that.
