Illegal opcode on ATtiny Topic is solved
Moderators: tfAteba, utzig
mikenick42
Postby mikenick42 » Thu Mar 11, 2021 1:53 am
I'm trying to modify the ATtiny demos to work on an ATtiny85 and keep getting:
/tmp/ccqAUctt.s: Assembler messages:
/tmp/ccqAUctt.s:255: Error: illegal opcode jmp for mcu avr25
make: *** [../../ChibiOS/os/common/ports/AVR/compilers/GCC/rules.mk:174: build/obj/chcore.o] Error 1
To get that far I had to set it change the entry in the Makefile from
MCU = attiny167
to
MCU = attiny85
as well as cutting out the UART related functions.
I would be tempted to say it's not worth it because the chip only has 8K of flash, but hal_st_lld has an __AVT_ATtiny85__ macro, so there's been at least some effort to make it work.
Is there some other piece that I'm missing?
tfAteba
Has thanked: 91 times
Been thanked: 50 times
Re: Illegal opcode on ATtiny
Postby tfAteba » Mon Jun 14, 2021 1:28 pm
Hello mokenick42,
Can you give me your setting? (ChibiOS version, board, changes made, a patch will be perfect)
so that I can reproduice your error?
Some time ago, I make ChibiOS to work on ATiny85, so it is possible, but it is hard to tell you what is you problem with the given information.
tfAteba
Re: Illegal opcode on ATtiny  Topic is solved
Postby tfAteba » Mon Jun 14, 2021 1:31 pm
I just found the link to my git hub where I made attiny85 ChibiOS port:
https://github.com/tfateba/chibios-on-attiny85
You can then take a look to this port to do what you need :)
Return to “AVR Support”
Users browsing this forum: No registered users and 104 guests
