Where is the PRIO ?
alexblack
Been thanked: 33 times
Where is the PRIO ?
Post by alexblack »
Hi.
Some time ago I used SystemView from SEGGER and made some code for it to support the ChibiOS.
Now this code do not compile because I used the member "prio" from struct "ch_thread". But now there is no it.
The code for SystemView was:
 * @brief   Context switch hook.
 * @details This hook is invoked just before switching between threads.
#if SYSVIEW_ENABLE == 1
#if SYSVIEW_CFG_HIDE_IDLE == TRUE
#define CH_CFG_CONTEXT_SWITCH_HOOK(ntp, otp) {                              \
  /* Context switch code here.*/                                            \
  if (otp->prio != IDLEPRIO)                                                \
    SEGGER_SYSVIEW_OnTaskStopExec();                                        \
  if (ntp->prio == IDLEPRIO)                                                \
    SEGGER_SYSVIEW_OnIdle();                                                \
  } else        \
    SEGGER_SYSVIEW_OnTaskStartExec((unsigned)ntp);                          \
#else
In this hook we decied what kind of the CONTEXT switch was heppen and call the desired functions from SystemView for that.
and else
 /* Scanning registry.*/
  syssts_t sts = chSysGetStatusAndLockX();
  ctp = ch.rlist.newer;
  chSysRestoreStatusX(sts);
  do {
    /* Exclude IDLE THREAD from list */
    if (ctp->prio != IDLEPRIO)
In this code we produce the list of all threads exclude idle thread.
Please help. How can I implement this code in new version of the ChibiOS? In older versions it work very well and was very helpfull.
Re: Where is the PRIO ?
Just replace the expression "->prio" with "->hdr.pqueue.prio".
alexblack
Post by alexblack »
Thank you. I will try.
