For debugging board, I want to use my E407 as a null modem usb adapter, It will take a usb CDC on port HS (as master), and slave on the FS port;
I understand, I need to thread and wakeup, but I could not achieved to get correct USB descriptor. Could you point to some code ?
Bastien
Olimex E407 USB HS + FS null modem
Re: Olimex E407 USB HS + FS null modem
The closest thing is the demo STM3F4xx-USB_CDC_IAD which implements 2 ports.
Hi Giovani,
I tried but it failed.
I have replaced one usbd2 by an usbd1 at the end of the testhal directory (not demo BTW).
Do you have idea why it does not work ?
It could depend on a lot of things: ULPI settings, GPIOs, clocks, descriptors. I haven't tested that demo for a while, it is possible that it regressed somehow.
Make it work with a single CDC first to make sure HW is fine.
