can_lld_set_filters (stm32 CANv1) clobbers filters if called multiple times
faisal
Has thanked: 45 times
Been thanked: 62 times
Post by faisal »
If you call canSTM32SetFilters multiple times, even without overlapping filter numbers in the passed in CANFilter struct, can_lld_set_filters clears our previously configured filters. This does not allow you to incrementally add to the configured filters. This is strange because the loop in can_lld_set_filters where it writes to the filter registers actually respects the filter number that you passed in thru CANFilter. The following is a small reordering which will 'fix' it.
static void can_lld_set_filters(CANDriver* canp,
                                uint32_t can2sb,
                                uint32_t num,
                                const CANFilter *cfp) {
    uint32_t i;
#if STM32_CAN_USE_CAN2
  if (canp == &CAND2) {
    /* Set handle to CAN1, because CAN1 manages the filters of CAN2.*/
    canp = &CAND1;
  /* Temporarily enabling CAN clock.*/
#if STM32_CAN_USE_CAN1
  if (canp == &CAND1) {
    rccEnableCAN1(true);
    /* Filters initialization.*/
    canp->can->FMR = (canp->can->FMR & 0xFFFF0000) | CAN_FMR_FINIT;
    canp->can->FMR = (canp->can->FMR & 0xFFFF0000) | (can2sb << 8) | CAN_FMR_FINIT;
#if STM32_CAN_USE_CAN3
  if (canp == &CAND3) {
    rccEnableCAN3(true);
  if (num > 0) {
    uint32_t fmask;
    /* Scanning the filters array.*/
    for (i = 0; i < num; i++) {
      fmask = 1 << cfp->filter;
      if (cfp->mode)
        canp->can->FM1R |= fmask;
      if (cfp->scale)
        canp->can->FS1R |= fmask;
      if (cfp->assignment)
        canp->can->FFA1R |= fmask;
      canp->can->sFilterRegister[cfp->filter].FR1 = cfp->register1;
      canp->can->sFilterRegister[cfp->filter].FR2 = cfp->register2;
      canp->can->FA1R |= fmask;
      cfp++;
  else {
    /* All filters cleared.*/
    canp->can->FA1R = 0;
    canp->can->FM1R = 0;
    canp->can->FS1R = 0;
    canp->can->FFA1R = 0;
    if(canp == &CAND1) {
      for (i = 0; i < STM32_CAN_MAX_FILTERS; i++) {
        canp->can->sFilterRegister[i].FR1 = 0;
        canp->can->sFilterRegister[i].FR2 = 0;
    if(canp == &CAND3) {
      for (i = 0; i < STM32_CAN3_MAX_FILTERS; i++) {
    /* Setting up a single default filter that enables everything for both
       CANs.*/
    canp->can->sFilterRegister[0].FR1 = 0;
    canp->can->sFilterRegister[0].FR2 = 0;
      canp->can->sFilterRegister[can2sb].FR1 = 0;
      canp->can->sFilterRegister[can2sb].FR2 = 0;
    canp->can->FS1R = 1;
    canp->can->FA1R = 1;
      canp->can->FS1R |= 1 << can2sb;
      canp->can->FA1R |= 1 << can2sb;
  canp->can->FMR &= ~CAN_FMR_FINIT;
  /* Clock disabled, it will be enabled again in can_lld_start().*/
    rccDisableCAN1();
    rccDisableCAN3();
Re: can_lld_set_filters (stm32 CANv1) clobbers filters if called multiple times
I am not sure about this, this function is a "set" filters, not an "add" filters". Not saying that it would not be useful but it would also require something to clear filters and start over.
steved
Has thanked: 12 times
Been thanked: 138 times
Post by steved »
Have a look at the attached; think it contains some useful routines for setting single filters.
(Don't adopt it wholesale; it's not been brought up to date with latest Chibi version, and may have other surprises; but it does work)
CANv1.7z
(8.48 KiB) Downloaded 637 times
faisal
Post by faisal »
Giovanni wrote:Hi,
Okay, so maybe add another function to clear out all the filters?
