chSysLock() recursion
Posted: Wed Aug 29, 2012 10:46 pm
by skute
Greetings,
I am new to ChibiOS, so please correct me if my understanding is wrong, but it seems that chSysLock() is not meant to be called recursively. This can lead to unexpected behavior; consider the following simple code example:
int func2data = 0;
void func2(void)
    chSysLock();
    func2data += 1;
    chSysUnlock();
int func1(void)
    chSysLock();
    func2();
     * At this point we expect to be in a locked context, but we aren't because
     * chSysUnlock() from above has unlocked the system.
    func3();
    chSysUnlock();
    return 0;
Is there an option to enable chSysLock() to be recursive? For example:
int func2data = 0;
void func2(void)
    chCpuState_t savedState;
    chSysLock(&savedState);
    func2data += 1;
    chSysUnlock(&savedState);
int func1(void)
    func2();
    func3();
    return 0;
=skute
Re: chSysLock() recursion
Posted: Thu Aug 30, 2012 4:50 am
by skute
One potential solution that I've come up with is as follows:
chconf.h
 * @brief   Threads descriptor structure extension.
 * @details User fields added to the end of the @p Thread structure.
#if !defined(THREAD_EXT_FIELDS) || defined(__DOXYGEN__)
#define THREAD_EXT_FIELDS                                                   \
  unsigned int lockStatus;                                                  \
  unsigned int lockCnt;
 * @brief   Threads initialization hook.
 * @details User initialization code added to the @p chThdInit() API.
 * @note    It is invoked from within @p chThdInit() and implicitly from all
 *          the threads creation APIs.
#if !defined(THREAD_EXT_INIT_HOOK) || defined(__DOXYGEN__)
#define THREAD_EXT_INIT_HOOK(tp) {                                          \
  /* Add threads initialization code here.*/                                \
  tp->lockStatus = 0;                                                        \
  tp->lockCnt    = 0;                                                        \
chcore_v7m.h
#if !defined(CORTEX_SIMPLIFIED_PRIORITY)
#define CORTEX_SIMPLIFIED_PRIORITY      TRUE
chcore_v7m.c
unsigned int __attribute__((naked))
_lock(void)
    unsigned int primask;
    __asm("    mrs     r0, PRIMASK\n"
          "    cpsid   i\n"
          "    bx      lr\n"
          : "=r" (primask));
    // avoid compiler warning
    return primask;
void __attribute__((naked))
_unlock(unsigned int status)
    __asm("    msr     PRIMASK, r0\n"
          "    bx      lr\n");
void _port_lock(void) {
  Thread *tp = chThdSelf();
    if (0 == tp->lockCnt) {
        tp->lockStatus = _lock();
    tp->lockCnt += 1;
void _port_unlock(void) {
    if (tp->lockCnt > 0) {
        tp->lockCnt -= 1;
            _unlock(tp->lockStatus);
            tp->lockStatus = 0;
I believe this will do what I'm looking for and avoids having to define a variable everywhere you use chSysLock(). Thoughts?
Posted: Thu Aug 30, 2012 7:43 am
ChSysLock and chSysUnlock are meant to not be nest-able in order to make them as fast as possible. The whole OS code is designed around not needing nesting and, in general, you can reorganize any code to do the same.
In version 2.2.x there was an option to make them nest-able but it has since removed, you may use that version (still supported) or paste that implementation into the current version. See chsys.h, the implementation requires an extra field in each Thread structure, you can add it using the hook macro THREAD_EXT_FIELDS. It is very similar to what you suggested.
Posted: Thu Aug 30, 2012 7:44 am
by mabl
skute,
there was once an option for recursive syslocks which has been removed since some time now. There is a better solution to you problem:
Always think about from where your function is called. If your function is also called from a locked zone, suffix it with I: i.e.
fooI() {
 // Do something
foo() {
chSysLock();
fooI();
chSysUnlock();
You might want to have a look at some ChibiOS functions, they do it exactly this way.
EDIT: Rule: Giovanni is ALWAYS faster.
Posted: Thu Aug 30, 2012 7:46 am
Mabl and I often trigger a race condition in the forum code :-)
What he suggested is what we usually do in order to not depend on recursive locks.
Posted: Thu Aug 30, 2012 4:02 pm
by skute
Greetings,
Thanks for the reply's. The 2.2.x branch looks like a simple solution for the short term. I'll add an assert in the nesting case and to track down any offending code which and re-write it to be non-nesting.
Cheers!
