Page 1 of 2
STM32G071 ADC resolution is always 12 bits
Posted: Tue Mar 01, 2022 4:05 pm
by dmene
I am doing tests with the ADC of the STM32G071 and it is not possible to change the
resolution is always 12 bits.
.cfgr1 = ADC_CFGR1_RES_10BIT |
ADC_CFGR1_EXTEN_RISING |
ADC_CFGR1_EXTSEL_SRC(5),
Daniel
Re: STM32G071 ADC resolution is always 12 bits
Posted: Tue Mar 01, 2022 6:29 pm
The driver does not enforce 12 bits, is the value of the CFGR1 register what you expect after starting the conversion? perhaps that setting is not reaching the ADC for some reason.
Posted: Tue Mar 01, 2022 6:42 pm
by dmene
yes, the setting does not reach the ADC, regardless of the setting, bits 3 and 4 of CFGR1 remain at 0.
Daniel
Posted: Tue Mar 01, 2022 7:57 pm
Is that structure actually passed to adcStartConversion() ? please try to step into adc_lld_start_conversion() until the register is actually written (line 311), please check the value there.
Posted: Tue Mar 01, 2022 8:36 pm
by dmene
const ADCConversionGroup adcgrpcfg1 =
.circular = true,
.num_channels = ADC_GRP1_NUM_CHANNELS,
.end_cb = adcCallback, // NULL,
.error_cb = adcErrorCallback,
.cfgr1 = ADC_CFGR1_RES_12BIT |
.cfgr2 = 0xCD,
adcStartConversion(&ADCD1, &adcgrpcfg1, samples1, ADC_GRP1_BUF_DEPTH);
CFGR1 0x00000543
CFGR2 0x000000CD
Daniel
Posted: Tue Mar 01, 2022 8:40 pm
by dmene
Sori,
CFGR1 0x00000543
Posted: Tue Mar 01, 2022 9:09 pm
I am trying to understand if the driver writes the correct value and it is not "taken" by the CFGR1 register. What is the value of the "cfgr1" variable just before it is written in the register?
  /* ADC configuration and start.*/
  adcp->adc->CFGR1  = cfgr1;
There are 2 cases:
1) The variable has the correct value and it is not latched into the register for some HW reason, then OK, we need to understand why.
2) The variable itself has a wrong value, this could be a SW bug in the driver somewhere (but I don't see anything in the code right now).
Debugging should be easier compiling with -O0 or optimizations could fool the debugger.
Posted: Tue Mar 01, 2022 9:29 pm
by dmene
The cfgr1 variable has an incorrect value.
I defined a variable:
uint32_t CFGR1x;
CFGR1x = cfgr1;
Then the value of CFGR1x is 0x00000543 (it should be 0x0000054B)
Daniel
Posted: Wed Mar 02, 2022 12:57 am
by dmene
I did this test, something is writing in the structure.
uint32_t CFGR1x, CFGR1y, CFGR1z;
CFGR1x = ADC_CFGR1_RES_10BIT | ADC_CFGR1_EXTEN_RISING | ADC_CFGR1_EXTSEL_SRC(5) | ADC_CFGR1_DMAEN | ADC_CFGR1_DMACFG ;
adcp->adc->CFGR1 = CFGR1x; // cfgr1;
CFGR1y = adcp->adc->CFGR1;
CFGR1z = CFGR1x;
CFGR1x 0x0000054B
CFGR1y 0x00000543
CFGR1z 0x0000054B
Daniel
Posted: Wed Mar 02, 2022 2:23 am
by psyco
This appears to be an errata. See ES0418 2.6.2, "Writing ADC_CFGR1 register while ADEN bit is set resets RES[1:0] bitfield".
