Chibistudio Debug View RT3.x.x
Posted: Wed Apr 06, 2022 4:23 pm
Hi all,
I am working with an application that is still using ChibiOS 3.0.5 and want to debug threading via ChibiStudio (I am using the most recent version). However, am I correct in concluding that I can only debug RT 6 and 7 with this version? In the debug view I can add a window for Debug View RT 3.x.x, but this throws an error as listed below. Is there another way to be able to debug RT3 similar to what is described here?
Thanks for taking the time in advance.
Remi
Remi
eclipse.buildId=4.15.0.I20200305-0155
java.version=11.0.14.1
java.vendor=Ubuntu
BootLoader constants: OS=linux, ARCH=x86_64, WS=gtk, NL=en_US
Framework arguments: -product org.eclipse.epp.package.java.product
Command-line arguments: -data /home/remi/ChibiStudio/workspace_user -os linux -ws gtk -arch x86_64 -product org.eclipse.epp.package.java.product
org.eclipse.jface
Error
Wed Apr 06 17:12:08 CEST 2022
Unable to resolve plug-in "org.chibios.tools.eclipse.debug.chibiosrt3".
java.io.IOException: Unable to resolve plug-in "org.chibios.tools.eclipse.debug.chibiosrt3".
at org.eclipse.core.internal.runtime.PlatformURLPluginConnection.parse(PlatformURLPluginConnection.java:64)
at org.eclipse.core.internal.runtime.PlatformURLPluginConnection.resolve(PlatformURLPluginConnection.java:73)
at org.eclipse.core.internal.boot.PlatformURLHandler.openConnection(PlatformURLHandler.java:69)
at org.eclipse.osgi.internal.url.URLStreamHandlerProxy.openConnection(URLStreamHandlerProxy.java:123)
at java.base/java.net.URL.openConnection(URL.java:1099)
at org.eclipse.core.internal.runtime.PlatformURLConverter.toFileURL(PlatformURLConverter.java:34)
at org.eclipse.core.runtime.FileLocator.toFileURL(FileLocator.java:261)
at org.eclipse.jface.resource.URLImageDescriptor.getFilePath(URLImageDescriptor.java:232)
at org.eclipse.jface.resource.URLImageDescriptor.access$2(URLImageDescriptor.java:220)
at org.eclipse.jface.resource.URLImageDescriptor$URLImageFileNameProvider.getImagePath(URLImageDescriptor.java:57)
at org.eclipse.swt.internal.DPIUtil.validateAndGetImagePathAtZoom(DPIUtil.java:422)
at org.eclipse.swt.graphics.Image.<init>(Image.java:657)
at org.eclipse.jface.resource.URLImageDescriptor.createImage(URLImageDescriptor.java:263)
at org.eclipse.jface.resource.ImageDescriptor.createResource(ImageDescriptor.java:204)
at org.eclipse.jface.resource.DeviceResourceManager.allocate(DeviceResourceManager.java:55)
at org.eclipse.jface.resource.AbstractResourceManager.create(AbstractResourceManager.java:88)
at org.eclipse.jface.resource.ResourceManager.createImageWithDefault(ResourceManager.java:195)
at org.eclipse.jface.resource.ImageRegistry.get(ImageRegistry.java:206)
at org.eclipse.e4.ui.workbench.renderers.swt.SWTPartRenderer.getImageFromURI(SWTPartRenderer.java:219)
at org.eclipse.e4.ui.workbench.renderers.swt.SWTPartRenderer.getImage(SWTPartRenderer.java:229)
at org.eclipse.e4.ui.workbench.renderers.swt.StackRenderer.createTab(StackRenderer.java:880)
at org.eclipse.e4.ui.workbench.renderers.swt.LazyStackRenderer.processContents(LazyStackRenderer.java:145)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:676)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:768)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.access$0(PartRenderingEngine.java:739)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$2.run(PartRenderingEngine.java:733)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:45)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:717)
at org.eclipse.e4.ui.workbench.renderers.swt.SWTPartRenderer.processContents(SWTPartRenderer.java:71)
at org.eclipse.e4.ui.workbench.renderers.swt.SashRenderer.processContents(SashRenderer.java:148)
at org.eclipse.e4.ui.workbench.renderers.swt.PerspectiveRenderer.processContents(PerspectiveRenderer.java:51)
at org.eclipse.e4.ui.workbench.renderers.swt.PerspectiveStackRenderer.showTab(PerspectiveStackRenderer.java:82)
at org.eclipse.e4.ui.workbench.renderers.swt.LazyStackRenderer.postProcess(LazyStackRenderer.java:105)
at org.eclipse.e4.ui.workbench.renderers.swt.PerspectiveStackRenderer.postProcess(PerspectiveStackRenderer.java:64)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:680)
at org.eclipse.e4.ui.workbench.renderers.swt.WBWRenderer.processContents(WBWRenderer.java:666)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$5.run(PartRenderingEngine.java:1086)
at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:338)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1049)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:155)
at org.eclipse.ui.internal.Workbench.lambda$3(Workbench.java:658)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:557)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:154)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:150)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:203)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:137)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:107)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:401)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:255)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.base/java.lang.reflect.Method.invoke(Method.java:566)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:657)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:594)
at org.eclipse.equinox.launcher.Main.run(Main.java:1447)
at org.eclipse.equinox.launcher.Main.main(Main.java:1420)
