Hello Team,
I want to integrate I2C interface to use eeprom AT24CS04-SSHM-T. This eeprom's slave found in Arduino but not in this STM board by using I2C scanner program. I have anothe I2C device IMU6050 that address is found in this STM board.
Is there anything that I am missing.
stm32f4029 Disc Board I2C v1 Integration for AT24CS04-SSHM-T
Re: stm32f4029 Disc Board I2C v1 Integration for AT24CS04-SSHM-T
Could it be a physical connection problem?
Hello Sir,
All the connection has verified and the clock/data validated on DSO but stll ACK bit is not detected on SDA.
Is the I2C address right? if there is no ACK then it is probably wrong.
You know, you have the debugger, I can just make random guesses.
Hello Sir,
I2C slave address is right (0xA0). Anyway I am using I2C scanner in which I m polling the address from 1 to 511 but for none of the address ACK is receiving.
In chibios for I2C scanner how it is working ?
Addresses in ChibiOS are just the 7 address bits, if the address byte is 0xA0 then the ChibiOS address is 0x50, the R/W bit is not considered.
If the DSO showed the known correct address with a NACK, you are likely push-pulling instead of open-draining the I2C lines.
If you are using palSetLineMode, fix it by changing the SDA / SCL lines to something like
Alternatively, change the output type of the lines in the board.chcfg / board.h files to open-drain.
palSetLineMode(x, PAL_MODE_ALTERNATE(n) | PAL_STM32_OTYPE_OPENDRAIN);Alternatively, change the output type of the lines in the board.chcfg / board.h files to open-drain.
