Gwen Port to Chibios/GFX
Has thanked: 876 times
Been thanked: 750 times
Re: Gwen Port to Chibios/GFX
Postby Giovanni » Thu Sep 13, 2012 8:11 am
Excellent, the graphic subsystem is maturing so fast. I have to buy something with a suitable LCD now :)
miguelmoreto
Postby miguelmoreto » Wed Sep 19, 2012 6:50 pm
Hello Giovanni,
I've made my own adapter board with LCD and Ethernet PHY board interface headers:
https://sites.google.com/site/miguelmor ... pter-board
There is a STM32F4 Motherboard at ebay, with the same functionality and embedded ethernet adapter, it costs about US$70,00 including the LCD.
Best regards!
Miguel
Postby Giovanni » Wed Sep 19, 2012 7:19 pm
Nice board, is the one on ebay electrically the same?
miguelmoreto
Postby miguelmoreto » Wed Sep 19, 2012 8:05 pm
Not exactly the same. I checked the schematics, here are the differences:
1) ebay board uses PE3 (address A19) for FSMC.
2) ebay board uses a 40 pin LCD. The LCD I use has 34 pins (HY32D), header have different pinouts (not the same LCD).
3) Backlight control pin is PC6 in my board, ebay board uses PB0.
4) I could not figure out which SPI is used in ebay board (strange pins used). My board uses PC10, PC11 and PC12 as SPI3 signals. These pins are used for serial and SD card reader in ebay board.
5) ebay board has camera header, RS232 converter and DB9 connector and CAN header.
These are the basic differences I have noted. Connection to PHY adapter seens to be the same.
Feel free to contribute to my board layout and connections if want.
Best regards,
Miguel
Badger
Postby Badger » Wed Sep 19, 2012 9:08 pm
miguelmoreto wrote:1) ebay board uses PE3 (address A19) for FSMC.
This is a minor issue, you would just have to change the LCD_RAM address. When the interface logic for 8080 or whatever it is called has been put in one place we could add macros for specifying this stuff.
miguelmoreto
Postby miguelmoreto » Wed Sep 19, 2012 9:47 pm
Yes Badger that is not a problem, for shure the GDISP will work with that board too.
Regards
Miguel
Postby Tectu » Sat Sep 22, 2012 10:57 pm
I finally found some time to make it run on my F1. Very impressive work.
Thank you very much, mobyfab!
DeusExMachina
Has thanked: 3 times
Postby DeusExMachina » Wed Mar 27, 2013 7:01 pm
What about non ASCII fonts? Can I use cyrillic fonts for example?
Postby Tectu » Fri Mar 29, 2013 4:36 pm
GWEN is currently not supported anymore. There have been a lot of changes and improvements in the ChibiOS/GFX library and there will come more in the near future.
mobyfab
Has thanked: 20 times
Been thanked: 28 times
Postby mobyfab » Wed Apr 03, 2013 9:55 am
DeusExMachina wrote:What about non ASCII fonts? Can I use cyrillic fonts for example?
You can use unicode but it is disabled by default to save space.
I am currently working on another project but I'll fix the SSD1963 driver and Gwen for GFX as soon as I can.
