F412 PLL clock config
hybridA
Has thanked: 10 times
Been thanked: 5 times
Postby hybridA » Mon Aug 08, 2022 2:26 am
I'm using an F412RE with an 8MHz oscillator.
Using this config (generated with the ST clock config tool, to get a 100MHz sysclk) it gets stuck forever, waiting for HSE to stabilize:
#define STM32_BKPRAM_ENABLE                 FALSE
#define STM32_HSI_ENABLED                   TRUE
#define STM32_LSI_ENABLED                   TRUE
#define STM32_CLOCK48_REQUIRED              TRUE
#define STM32_PLLM_VALUE                    8
#define STM32_PLLN_VALUE                    200
#define STM32_PLLP_VALUE                    4
#define STM32_PLLQ_VALUE                    9
#define STM32_PLLR_VALUE                    4
Can you point me to a sane config for using an 8MHz external oscillator?
Edit: I think i found the issue, I had STM32_HSE_BYPASS defined...
thank you
Return to “STM32 Support”
