LWIP Problem UDP
Posted: Thu Sep 13, 2012 1:24 pm
by stormracer
Hello
i'm working on a project with LWIP on the stm32f4 discovery. Therefor i have three threads which handles the ethernet connection.
One thread receive packages and put them on can bus. Another receive can packages an send them on udp. A third thread send on udp parallel.
My problem is, when only the can bus threads are active all is working, but when i enable the third thread the other doesn't receive packages any more.
My code for udp is:
UDP receive
conn = netconn_new(NETCONN_UDP);
if((t = netconn_bind(conn, IP_ADDR_ANY, 1242)) != ERR_OK)
   chprintf((BaseSequentialStream *)&SD1, "ERROR %d\r\n", t);
   for(;;){
      err = netconn_recv(conn, &buf);
UDP send
conn = netconn_new( NETCONN_UDP );
netconn_bind(conn, IP_ADDR_ANY, 1234 ); //local port
netconn_connect(conn, IP_ADDR_BROADCAST, 1235 );
buf = netbuf_new();
for(;;){
   netconn_send(conn, buf);
UDP send parallel
//netconn_bind(conn, IP_ADDR_ANY, 1240 ); //local port
netconn_connect(conn, IP_ADDR_BROADCAST, 1241 );
buf = netbuf_new();
for(;;){
If I enable this code the other thread doesn't receive anything. Without this all is working.
A port scan with nmap shows that the port 1242 is "1242/udp open|filtered unknown".
Christian
Re: LWIP Problem UDP
Posted: Thu Sep 13, 2012 2:15 pm
I am not an lwIP expert, are those lwIP functions reentrant? if not you cannot call them from different threads.
Just to be sure, check thread stacks.
Posted: Thu Sep 13, 2012 2:17 pm
by mabl
Looks good to me. Note that you might run out of netconn/udp buffers or so. Check the return error codes and have a look at the Lwip error statistics (see the console example in the lwip contrib repo.)
@Givoanni: netconn is reentrant. RAW API is not.
Posted: Thu Sep 13, 2012 5:53 pm
by stormracer
thanks for the hint with the statistics. But i found no error or problem.
I have attached a test output after sending 15 UDP Packets, i expect 15 answer packets but i got only one. After the third thread is ready reinitialized, i got no packet.
Stats UDP
recv 15
cachehit 0
checkerr 0
drop 0
err 0
fw 0
lenerr 0
memerr 0
opterr 0
proterr 0
rterr 0
xmit 4
Stats SYS
sys mbox 4
sys mutex 0
sys sem 5
Stats MEM
mem avail 1600
mem err 0
mem illegal 0
mem max 208
mem used 208
Stats Link
Recv 19
cachehit 0
checkerr 0
drop 0
err 0
fw 0
lenerr 0
memerr 0
opterr 0
proterr 0
rterr 0
xmit 6
I think the stats are Okay.
Christian
