Trying to use <string>
Posted: Fri Dec 30, 2022 5:16 pm
by oszfather
my 'main' source file is a cpp file. I've been using this fine with chibios along with some cpp libraries for some time (the makefile knows theyre cpp). I want to perform some string manipulation and so need the string library so I import the following:
#include <string.h>
#include <stdlib.h>
#include <iostream>
using namespace std;
and make use of the string data type and strncmp function:
string test = "blah";
if(strncmp("GT",(char*)buffer,2) == 0){
      cmd = 1;
Upon building I get the following errors:
Linking build/ch.elf
lto-wrapper.exe: warning: Options to Xassembler do not match: -alms=./build/lst/crt1.lst, -alms=./build/lst/hal.lst, dropping all -Xassembler and -Wa options.
c:/chibistudio/tools/gnu tools arm embedded/10.3 2021.07/bin/../lib/gcc/arm-none-eabi/10.3.1/../../../../arm-none-eabi/bin/ld.exe: C:\Users\zinvi\AppData\Local\Temp\ch.elf.WOywVb.ltrans0.ltrans.o: in function `main':
c:\chibistudio\tools\gnu tools arm embedded\10.3 2021.07\arm-none-eabi\include\c++\10.3.1\bits/basic_string.tcc:225: undefined reference to `std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >::_S_copy_chars(char*, char const*, char const*)'
c:/chibistudio/tools/gnu tools arm embedded/10.3 2021.07/bin/../lib/gcc/arm-none-eabi/10.3.1/../../../../arm-none-eabi/bin/ld.exe: C:\Users\zinvi\AppData\Local\Temp\ch.elf.WOywVb.ltrans0.ltrans.o: in function `_GLOBAL__sub_I__Z15ApplicationInitv':
c:\chibistudio\tools\gnu tools arm embedded\10.3 2021.07\arm-none-eabi\include\c++\10.3.1/iostream:74: undefined reference to `std::ios_base::Init::Init()'
c:/chibistudio/tools/gnu tools arm embedded/10.3 2021.07/bin/../lib/gcc/arm-none-eabi/10.3.1/../../../../arm-none-eabi/bin/ld.exe: C:\Users\zinvi\AppData\Local\Temp\ch.elf.WOywVb.ltrans0.ltrans.o:c:\chibistudio\tools\gnu tools arm embedded\10.3 2021.07\arm-none-eabi\include\c++\10.3.1/iostream:74: undefined reference to `__dso_handle'
c:/chibistudio/tools/gnu tools arm embedded/10.3 2021.07/bin/../lib/gcc/arm-none-eabi/10.3.1/../../../../arm-none-eabi/bin/ld.exe: C:\Users\zinvi\AppData\Local\Temp\ch.elf.WOywVb.ltrans0.ltrans.o:c:\chibistudio\tools\gnu tools arm embedded\10.3 2021.07\arm-none-eabi\include\c++\10.3.1/iostream:74: undefined reference to `std::ios_base::Init::~Init()'
c:/chibistudio/tools/gnu tools arm embedded/10.3 2021.07/bin/../lib/gcc/arm-none-eabi/10.3.1/../../../../arm-none-eabi/bin/ld.exe: c:/chibistudio/tools/gnu tools arm embedded/10.3 2021.07/bin/../lib/gcc/arm-none-eabi/10.3.1/../../../../arm-none-eabi/lib/thumb/v7e-m/nofp\libg.a(lib_a-fini.o): in function `__libc_fini_array':
fini.c:(.text.__libc_fini_array+0x20): undefined reference to `_fini'
c:/chibistudio/tools/gnu tools arm embedded/10.3 2021.07/bin/../lib/gcc/arm-none-eabi/10.3.1/../../../../arm-none-eabi/bin/ld.exe: c:/chibistudio/tools/gnu tools arm embedded/10.3 2021.07/bin/../lib/gcc/arm-none-eabi/10.3.1/../../../../arm-none-eabi/lib/thumb/v7e-m/nofp\libg.a(lib_a-abort.o): in function `abort':
abort.c:(.text.abort+0xa): undefined reference to `_exit'
c:/chibistudio/tools/gnu tools arm embedded/10.3 2021.07/bin/../lib/gcc/arm-none-eabi/10.3.1/../../../../arm-none-eabi/bin/ld.exe: c:/chibistudio/tools/gnu tools arm embedded/10.3 2021.07/bin/../lib/gcc/arm-none-eabi/10.3.1/../../../../arm-none-eabi/lib/thumb/v7e-m/nofp\libg.a(lib_a-signalr.o): in function `_kill_r':
signalr.c:(.text._kill_r+0x12): undefined reference to `_kill'
c:/chibistudio/tools/gnu tools arm embedded/10.3 2021.07/bin/../lib/gcc/arm-none-eabi/10.3.1/../../../../arm-none-eabi/bin/ld.exe: c:/chibistudio/tools/gnu tools arm embedded/10.3 2021.07/bin/../lib/gcc/arm-none-eabi/10.3.1/../../../../arm-none-eabi/lib/thumb/v7e-m/nofp\libg.a(lib_a-signalr.o): in function `_getpid_r':
signalr.c:(.text._getpid_r+0x0): undefined reference to `_getpid'
c:/chibistudio/tools/gnu tools arm embedded/10.3 2021.07/bin/../lib/gcc/arm-none-eabi/10.3.1/../../../../arm-none-eabi/bin/ld.exe: build/ch.elf: hidden symbol `__dso_handle' isn't defined
c:/chibistudio/tools/gnu tools arm embedded/10.3 2021.07/bin/../lib/gcc/arm-none-eabi/10.3.1/../../../../arm-none-eabi/bin/ld.exe: final link failed: bad value
make: *** [../../../os/common/startup/ARMCMx/compilers/GCC/mk/rules.mk:217: build/ch.elf] Error 1
"make -j8 all" terminated with exit code 2. Build might be incomplete.
16:07:13 Build Failed. 17 errors, 5 warnings. (took 3s.187ms)
I tried adding the path 'C:\ChibiStudio\tools\GNU Tools ARM Embedded\10.3 2021.07' in both the C and C++ CDT user setting entries in the project preprocesser include paths (in project properties). This didnt fix anything. I'm not exactly an expert on the C build process and toolchain details, why wont these libraries be imported/linked correctly and how do I fix this?
Re: Trying to use <string>
Posted: Fri Dec 30, 2022 5:33 pm
Default makefiles link using gcc not g++ in order to save some space.
You may try to add:
LD = $(TRGT)g++
to your makefile soon after the inclusion of arm-none-eabi.mk in order to override this.
Posted: Fri Dec 30, 2022 7:05 pm
by oszfather
Giovanni wrote:Hi,
You may try to add:
LD = $(TRGT)g++
I added that line like so:
# Common rules
RULESPATH = $(CHIBIOS)/os/common/startup/ARMCMx/compilers/GCC/mk
include $(RULESPATH)/arm-none-eabi.mk
include $(RULESPATH)/rules.mk
# Common rules
# Custom rules
LD = $(TRGT)g++
But gave me almost double the errors:
c:/chibistudio/tools/gnu tools arm embedded/10.3 2021.07/bin/../lib/gcc/arm-none-eabi/10.3.1/../../../../arm-none-eabi/bin/ld.exe: C:\Users\zinvi\AppData\Local\Temp\ch.elf.34hhZP.ltrans0.ltrans.o: in function `_GLOBAL__sub_I__Z15ApplicationInitv':
c:/chibistudio/tools/gnu tools arm embedded/10.3 2021.07/bin/../lib/gcc/arm-none-eabi/10.3.1/../../../../arm-none-eabi/bin/ld.exe: c:/chibistudio/tools/gnu tools arm embedded/10.3 2021.07/bin/../lib/gcc/arm-none-eabi/10.3.1/../../../../arm-none-eabi/lib/thumb/v7e-m/nofp\libstdc++.a(system_error.o): in function `_GLOBAL__sub_I__ZSt20__throw_system_errori':
system_error.cc:(.text.startup._GLOBAL__sub_I__ZSt20__throw_system_errori+0x1c): undefined reference to `__dso_handle'
c:/chibistudio/tools/gnu tools arm embedded/10.3 2021.07/bin/../lib/gcc/arm-none-eabi/10.3.1/../../../../arm-none-eabi/bin/ld.exe: c:/chibistudio/tools/gnu tools arm embedded/10.3 2021.07/bin/../lib/gcc/arm-none-eabi/10.3.1/../../../../arm-none-eabi/lib/thumb/v7e-m/nofp\libstdc++.a(cxx11-ios_failure.o): in function `(anonymous namespace)::__io_category_instance()':
cxx11-ios_failure.cc:(.text._ZN12_GLOBAL__N_122__io_category_instanceEv+0x38): undefined reference to `__dso_handle'
c:/chibistudio/tools/gnu tools arm embedded/10.3 2021.07/bin/../lib/gcc/arm-none-eabi/10.3.1/../../../../arm-none-eabi/bin/ld.exe: c:/chibistudio/tools/gnu tools arm embedded/10.3 2021.07/bin/../lib/gcc/arm-none-eabi/10.3.1/../../../../arm-none-eabi/lib/thumb/v7e-m/nofp\libg.a(lib_a-fstatr.o): in function `_fstat_r':
fstatr.c:(.text._fstat_r+0x12): undefined reference to `_fstat'
c:/chibistudio/tools/gnu tools arm embedded/10.3 2021.07/bin/../lib/gcc/arm-none-eabi/10.3.1/../../../../arm-none-eabi/bin/ld.exe: c:/chibistudio/tools/gnu tools arm embedded/10.3 2021.07/bin/../lib/gcc/arm-none-eabi/10.3.1/../../../../arm-none-eabi/lib/thumb/v7e-m/nofp\libg.a(lib_a-sbrkr.o): in function `_sbrk_r':
sbrkr.c:(.text._sbrk_r+0xc): undefined reference to `_sbrk'
c:/chibistudio/tools/gnu tools arm embedded/10.3 2021.07/bin/../lib/gcc/arm-none-eabi/10.3.1/../../../../arm-none-eabi/bin/ld.exe: c:/chibistudio/tools/gnu tools arm embedded/10.3 2021.07/bin/../lib/gcc/arm-none-eabi/10.3.1/../../../../arm-none-eabi/lib/thumb/v7e-m/nofp\libg.a(lib_a-writer.o): in function `_write_r':
writer.c:(.text._write_r+0x14): undefined reference to `_write'
c:/chibistudio/tools/gnu tools arm embedded/10.3 2021.07/bin/../lib/gcc/arm-none-eabi/10.3.1/../../../../arm-none-eabi/bin/ld.exe: c:/chibistudio/tools/gnu tools arm embedded/10.3 2021.07/bin/../lib/gcc/arm-none-eabi/10.3.1/../../../../arm-none-eabi/lib/thumb/v7e-m/nofp\libg.a(lib_a-closer.o): in function `_close_r':
closer.c:(.text._close_r+0xc): undefined reference to `_close'
c:/chibistudio/tools/gnu tools arm embedded/10.3 2021.07/bin/../lib/gcc/arm-none-eabi/10.3.1/../../../../arm-none-eabi/bin/ld.exe: c:/chibistudio/tools/gnu tools arm embedded/10.3 2021.07/bin/../lib/gcc/arm-none-eabi/10.3.1/../../../../arm-none-eabi/lib/thumb/v7e-m/nofp\libg.a(lib_a-isattyr.o): in function `_isatty_r':
isattyr.c:(.text._isatty_r+0xc): undefined reference to `_isatty'
c:/chibistudio/tools/gnu tools arm embedded/10.3 2021.07/bin/../lib/gcc/arm-none-eabi/10.3.1/../../../../arm-none-eabi/bin/ld.exe: c:/chibistudio/tools/gnu tools arm embedded/10.3 2021.07/bin/../lib/gcc/arm-none-eabi/10.3.1/../../../../arm-none-eabi/lib/thumb/v7e-m/nofp\libg.a(lib_a-lseekr.o): in function `_lseek_r':
lseekr.c:(.text._lseek_r+0x14): undefined reference to `_lseek'
c:/chibistudio/tools/gnu tools arm embedded/10.3 2021.07/bin/../lib/gcc/arm-none-eabi/10.3.1/../../../../arm-none-eabi/bin/ld.exe: c:/chibistudio/tools/gnu tools arm embedded/10.3 2021.07/bin/../lib/gcc/arm-none-eabi/10.3.1/../../../../arm-none-eabi/lib/thumb/v7e-m/nofp\libg.a(lib_a-readr.o): in function `_read_r':
readr.c:(.text._read_r+0x14): undefined reference to `_read'
18:04:20 Build Failed. 31 errors, 6 warnings. (took 5s.398ms)
Did i add it incorrectly (I realised TRGT isnt an actual path but what should be there instead)?
how i do get the project to compile with g++ and not gcc.
Posted: Fri Dec 30, 2022 7:22 pm
Place it this way:
LD = $(TRGT)g++
It is rules.mk that uses that variable.
Posted: Fri Dec 30, 2022 7:24 pm
by oszfather
Giovanni wrote:Hi,
Place it this way:
LD = $(TRGT)g++
Hi, i've added it this way but it still gives me those 31 errors in my last reply.
Posted: Fri Dec 30, 2022 7:29 pm
Are you including /os/various/syscalls.c in your project? it is where those symbols are defined.
Posted: Fri Dec 30, 2022 7:44 pm
by oszfather
Giovanni wrote:Hi,
I couldnt see it anywhere so I've added it like so:
CSRC = $(ALLCSRC) \
       $(TESTSRC) \
       $(CHIBIOS)/os/various/syscalls.c
I'm getting 11 errors now
Posted: Fri Dec 30, 2022 8:20 pm
The OS includes a limited support for the newlib, apparently you are using library functions that rely on unimplemented system calls.
You need to provide a stub implementation for those undefined symbols like syscalls.c does.
More information is available here: http://sourceware.org/newlib/
Posted: Fri Dec 30, 2022 11:02 pm
by oszfather
Giovanni wrote:Hi,
Thanks for the advice thus far and to clear things up for my understanding. You're recommending I use an alternate to library like 'newlib' in the link you sent to act as a substitute for the string.h and stdlib.h etc. libraries. because these libraries rely on 'unimplemented system calls'? Is there anyway to use these original libraries as also I soon want to add libraries like 'Eigen' for C++ and do not want to run into similar linking issues?
Are there any docs on how ChibiOS build process works so I can improve my understanding of the entire thing?
Posted: Sat Dec 31, 2022 7:35 am
What version of GCC compiler are you using? it is already using newlib, my suggestion is to provide those unimplemented functions in your own project in order to silence those linker errors, the linker I sent is the documentation for those functions.
The build process is nothing peculiar, it is enclosed in that rules.mk file and it is shared among all projects. You can enable the "verbose" option in your makefile and you will see exactly all commands during build including the final link phase.
BTW, we have a discord server, you may try to ask in there too: https://discord.gg/s8b8v7VtrM
