Serial USB differences F413/F407
hybridA
Has thanked: 10 times
Been thanked: 5 times
Postby hybridA » Fri Feb 03, 2023 8:10 am
I'm porting code from an older board (running on F413) to a newer version with F407. I'm using Serial USB terminal for sending debugging data from the MCU to the PC. I noticed that the USB device didn't show up in dmesg/lsusb, so I stripped the code down to where all it does is
sduObjectInit(&SDU1);
sduStart(&SDU1, &serusbcfg);
This works fine on the F413 but doesn't work on the F407.
I verified my USB clock is running correctly at 48MHz.
I ultimately found a work-around for this so USB enumerates OK on the 407:
In stm32_registry.h, I had to change
#define STM32_OTG_STEPPING                  1
to
#define STM32_OTG_STEPPING                  2
I'm not exactly sure what that macro does, if that's a bug or if this is just masking a configuration issue on my side.
Thanks
Re: Serial USB differences F413/F407
Postby Giovanni » Fri Feb 03, 2023 8:38 am
Moving in "bug reports".
This is strange because F407 is very old and the driver is known to work, I need to verify on my old board and then on a newer board again.
Return to “Bug Reports”
Users browsing this forum: Bing [Bot] and 5 guests
