I have finally resolved all my issues with SDMMCv2. This is a summary of what I found, the patch we are using can be found at https://github.com/ArduPilot/ChibiOS.sv ... b6b579e67a
new link: https://github.com/ArduPilot/ChibiOS.sv ... bf195aafbd
1. There appears to be an issue with STM32_SDC_SDMMC_PWRSAV. I accidentally had this off (default is on) and I was getting DMA timeouts when teh card was being setup. These eventually resolved, but with it on there are no timeouts making me think there is a bug. In particular I am suspicious that perhaps the clock needs to be disabled when changing speeds.
2. CLKDIV is now 9 bits so the mask needs to be 0xFFFFFE00U
3. The changes to sdc_lld_read() and sdc_lld_write() with STM32_SDC_SDMMC_UNALIGNED_SUPPORT set means that blocks are always written in 512byte chunks, this turns out to be much slower than writing all at once which the old code allowed. I note that the old code still exists in SDIOv1.
4. __nocache_sd1_wbuf and __nocache_sd2_wbuf appear to be unecessary - the response is never used with DMA so no caching issues should occur.
5. MASK should be set inside the critical zone
I made some other changes related to DMA. I'm not totally sure whether they are strictly necessary, but the certainly work.
Various issues with SDMMCv2 Topic is solved
Users browsing this forum: Google [Bot] and 74 guests
