Run ChibiOS on linux in user mode
shizheng357
Post by shizheng357 »
Hi, I'm wondering if it is possible to run ChibiOS as a process on Ubuntu in user mode? The reason to do so is that we are developing a program analysis tool and would like to try it on some OS systems. Thanks.
Re: Run ChibiOS on linux in user mode
It is possible, there is a demo here: /demos/various/RT-Posix-Simulator
Your Ubuntu system needs to be configured to support 32 bits build environment. The demo emulates 2 serial ports or TCP ports 29001 29002, by connecting with telnet or some other terminal it is possible to interact with the shell.
shizheng357
Noted on this, thank you very much!
