STM32F373 DMA struggles
Posted: Sat Sep 23, 2023 4:48 pm
I am trying to use the SDADC and the DAC (both with 2 channels) with DMA on my custom STM32F373 board using ChibiOS 20.3.2.
In ChibiOS 20.3.2, both SDADC and DAC are configured to use the same DMA channels:
From ChibiOS-20.3.2/os/hal/ports/STM32/STM32F37x/stm32_registry.h
and from ChibiOS-20.3.2/os/hal/ports/STM32/STM32F37x/hal_adc_lld.c in void adc_lld_start(ADCDriver *adcp):
According to the reference manual, I should be able to change the ADC DMA from (2,3), (2,4) and (2,5) and (1,3), (1,4) and (1,5), but if I change the defines in stm32_registry.h to
the DMA doesn't work anymore (dac_lld_serve_tx_interrupt doesn't get called...). I found the following comment in ChibiOS-20.3.2/os/hal/ports/STM32/LLD/DMAv1/notes.txt
but I couldn't figure out what I have to add. Any hints what I can try to get this working?
BTW: Is there an easy way to figure out which version of a peripheral driver a certain chip is using? I mean how can one know if a STM32F4xx is using ADCv3 or ADCv4 or does a STM32F373 use DMAv1 or DMAv2? I think I figured it out for the STM32F373 that I am using, but it was somewhat difficult and I am wondering if there is a easy / recommended way to do this?
/* DAC attributes.*/
#define STM32_HAS_DAC1_CH1 TRUE
#define STM32_DAC_DAC1_CH1_DMA_STREAM STM32_DMA_STREAM_ID(2, 3)
#define STM32_HAS_DAC1_CH2 TRUE
#define STM32_DAC_DAC1_CH2_DMA_STREAM STM32_DMA_STREAM_ID(2, 4)
#define STM32_HAS_DAC2_CH1 TRUE
#define STM32_DAC_DAC2_CH1_DMA_STREAM STM32_DMA_STREAM_ID(2, 5)
#if STM32_ADC_USE_SDADC1
if (&SDADCD1 == adcp) {
adcp->dmastp = dmaStreamAllocI(STM32_DMA_STREAM_ID(2, 3),
STM32_ADC_SDADC1_DMA_IRQ_PRIORITY,
(stm32_dmaisr_t)adc_lld_serve_dma_interrupt,
(void *)adcp);
osalDbgAssert(adcp->dmastp != NULL, "unable to allocate stream");
dmaStreamSetPeripheral(adcp->dmastp, &SDADC1->JDATAR);
rccEnableSDADC1(true);
PWR->CR |= PWR_CR_SDADC1EN;
adcp->sdadc->CR2 = 0;
adcp->sdadc->CR1 = (adcp->config->cr1 | SDADC_ENFORCED_CR1_FLAGS) &
~SDADC_FORBIDDEN_CR1_FLAGS;
adcp->sdadc->CR2 = SDADC_CR2_ADON;
#endif /* STM32_ADC_USE_SDADC1 */
#if STM32_ADC_USE_SDADC2
if (&SDADCD2 == adcp) {
adcp->dmastp = dmaStreamAllocI(STM32_DMA_STREAM_ID(2, 4),
#define STM32_DAC_DAC1_CH1_DMA_STREAM STM32_DMA_STREAM_ID(1, 3)
#define STM32_DAC_DAC1_CH2_DMA_STREAM STM32_DMA_STREAM_ID(1, 4)
#define STM32_DAC_DAC2_CH1_DMA_STREAM STM32_DMA_STREAM_ID(1, 5)
- For devices without CSELR register it is possible to select channels but
the SYSCFG CFGR register is not configured, the user has to configure it
before starting the DMA driver.
