Improve simulator serial port performance
Posted: Mon Jan 29, 2024 5:09 pm
by jpa
The simulator serial port to TCP/IP connection is very useful for automated testing.
However, it is slow - in current ChibiOS code I get about 6 kB/s.
The patch below is a simple modification that handles serial interrupts in loop until the buffer is fully processed.
Operating system will usually combine the multiple 1-byte writes into a single TCP packet.
With the patch and 256 byte serial buffer size I get 300 kB/s transfer speed.
diff --git a/os/hal/ports/simulator/posix/hal_lld.c b/os/hal/ports/simulator/posix/hal_lld.c
index 29eb30659..71fb82011 100755
--- a/os/hal/ports/simulator/posix/hal_lld.c
+++ b/os/hal/ports/simulator/posix/hal_lld.c
@@ -73,7 +73,7 @@ void _sim_check_for_interrupts(void) {
   bool int_occurred = false;
 #if HAL_USE_SERIAL
-  if (sd_lld_interrupt_pending()) {
+  while (sd_lld_interrupt_pending()) {
     int_occurred = true;
diff --git a/os/hal/ports/simulator/win32/hal_lld.c b/os/hal/ports/simulator/win32/hal_lld.c
index 541b0f000..c967971ba 100644
--- a/os/hal/ports/simulator/win32/hal_lld.c
+++ b/os/hal/ports/simulator/win32/hal_lld.c
@@ -79,7 +79,7 @@ void _sim_check_for_interrupts(void) {
 #if HAL_USE_SERIAL
Re: Improve simulator serial port performance
Posted: Tue Jul 01, 2025 10:02 am
bump
Posted: Thu Jul 03, 2025 10:42 am
Change committed in trunk.
