Stop and start again chibios_rt::BaseStaticThread
Posted: Mon Mar 11, 2024 5:32 pm
by Dron_Gus
Hi
I'm working with ChibiOS 20.3
I have static thread based on chibios_rt::BaseStaticThread.
Code in this thread checks for chThdShouldTerminateX() on each iteration.
If chThdShouldTerminateX() == true it calls chThdExit((msg_t)0x0).
Now I want to stop this thread, apply new config and start it again.
I have chibios_rt::ThreadReference ref for this thread.
So I'm doing:
         /* Getting a reference.*/
         ref.addRef();
         /* Asking for thread termination.*/
         ref.requestTerminate();
           /* Waiting for termination, releasing the reference.*/
         ref.wait();
After this I see this thread in FINAL state:
  14   Thread 536891672 "MAX3185X" (Name: MAX3185X, State: FINAL)                          0x080072b6 in chSchGoSleepS (newstate=<optimized out>) at ChibiOS/os/rt/src/chschd.c:235
Looks ok so far.
But when I try to start this thread again chThdCreateStatic fails on following assertion:
#if (CH_CFG_USE_REGISTRY == TRUE) &&                                        \
    ((CH_DBG_ENABLE_STACK_CHECK == TRUE) || (CH_CFG_USE_DYNAMIC == TRUE))
  chDbgAssert(chRegFindThreadByWorkingArea(wsp) == NULL,
              "working area in use");
This is because thread is still in list. Comment to chRegFindThreadByWorkingArea function says:
Confirms that a working area is being used by some active thread.
Is thread with CH_STATE_FINAL state also considered active?
Am I missing some step after killing thread to remove it from registry?
If I just comment this assert in chThdCreateStatic then thread seems starts fine, but registry is corrupted, at least GDB shows only one task:
(gdb) info thread
  Id   Target Id                                                              Frame
* 16   Thread 1 "Current Execution" (Name: Current Execution, No RTOS thread) Vector108 () at ChibiOS/os/hal/ports/STM32/LLD/TIMv1/hal_pwm_lld.c:310
Am I missing something trivial?
Re: Stop and start again chibios_rt::BaseStaticThread
Posted: Mon Mar 11, 2024 5:41 pm
by Dron_Gus
Ok, it seems there is no need to take ref (addRef()) before calling requestTerminate() and wait()
Posted: Mon Mar 11, 2024 8:42 pm
You don't need addref if you already own a reference. By incrementing the reference counter you prevent the thread to be disposed.
Posted: Tue Mar 12, 2024 5:26 pm
by Dron_Gus
Giovanni wrote:You don't need addref if you already own a reference. By incrementing the reference counter you prevent the thread to be disposed.
Thank you for clarifying. I had wrong assumption that ref is decremented when thread exits.
Now without addRef everything works as expected.
