Atollic
Posted: Fri Feb 11, 2011 5:16 pm
by doodie
hi there,
i've got a problem. i got a STM32 Evalboard and a ST-Link programmer. Because of OpenOCD doesn't support this programmer i have to use Atollic True Studio Lite (
www.atollic.com) for programming.
When i tryed to set up Atollic like in the tutorial for eclipse, the system starts compileing the code but stops with the message:
make: *** [../../os/ports/GCC/ARMCMx/crt0_v7m.o] Error 2
could not find file.
maybe someone could give me a tipp where i have to search for the bug.
thanks
Re: Atollic
Posted: Fri Feb 11, 2011 7:24 pm
Are you able to compile the demo just using the command "make" from a command shell? this would let us understand if it is a problem in setting up the demo under Atollic or something else.
Re: Atollic
Posted: Sun Feb 20, 2011 1:44 am
by doodie
hi, sorry for beeing late!
yes i tryed to compile it from a command shell, but it seems that athollic uses some own kind of gcc. it provides commands like gcc, g++ and the make command. I think that this make.exe doesnt support all features of the linux version ( in my debian system make works well but there i have no ST-Link support).
Florian
Re: Atollic
Posted: Sun Feb 20, 2011 8:17 am
What I could do is to add an Atollic project file into some next version.
Note that ST-Link works perfectly under IAR Workbench and Keil uVision, you may give them a try if you don't mind the 32KB limitation.
It is a shame that ST-Link does not offer a generic GDB server out of the box. You need to replace its firmware if you want to use it with OpenOCD but it is not something I would really recommend because you wouldn't be able to restore it.
Re: Atollic
Posted: Sun Feb 20, 2011 10:45 am
by doodie
yes i know that IAR and Keil works with ST-Link but my company has decided to use Atollic. I would be glad if you could set up a atollic project in the next version.
when will the next version be released?
thanks!
Florian
Re: Atollic
Posted: Sun Feb 20, 2011 11:09 am
I'll try to add this in 2.3.0 which is the next development version. You may then back-port the project in the current stable version (2.2.1).
