Unsure about clock tree configuration (because the CANbus baud rate is not correct)
Posted: Thu Jan 30, 2025 10:52 am
by KoF
Hello everyone. Can one of you check if I have set my mcuconfig.h correctly? I have parameterised everything in STM32CubeMX to help me and (hopefully correctly) adopted it.
I'm using an STM32F4 with a 12MHz Osc
 * HAL driver system settings.
#define STM32_BKPRAM_ENABLE                 FALSE
#define STM32_CLOCK48_REQUIRED              TRUE
#define STM32_PLLM_VALUE                    6
#define STM32_PLLN_VALUE                    100
#define STM32_PLLP_VALUE                    2
#define STM32_PLLQ_VALUE                    2
#define STM32_PPRE1                         STM32_PPRE1_DIV2
#define STM32_PPRE2                         STM32_PPRE2_DIV1
#define STM32_PLLI2SSRC                     STM32_PLLI2SSRC_PLLSRC
#define STM32_I2SCKIN_VALUE                 0
#define STM32_PLLI2SM_VALUE                 8
#define STM32_PLLI2SN_VALUE                 192
#define STM32_PLLI2SR_VALUE                 4
#define STM32_PLLI2SQ_VALUE                 4
#define STM32_PLLI2SDIVR_VALUE              1
#define STM32_PLLDIVR_VALUE                 1
#define STM32_SAI1SEL                       STM32_SAI1SEL_OFF
#define STM32_SAI2SEL                       STM32_SAI2SEL_OFF
#define STM32_TIMPRE                        STM32_TIMPRE_PCLK
#define STM32_CK48MSEL                      STM32_CK48MSEL_PLL
#define STM32_RTCSEL                        STM32_RTCSEL_LSI
#define STM32_RTCPRE_VALUE                  8
#define STM32_MCO1SEL                       STM32_MCO1SEL_HSI
#define STM32_MCO1PRE                       STM32_MCO1PRE_DIV1
#define STM32_MCO2SEL                       STM32_MCO2SEL_SYSCLK
#define STM32_MCO2PRE                       STM32_MCO2PRE_DIV5
According to this, APB1 should be 50MHz, right?
If I now use this 50MHz for the calculation of a CANbus baud rate, then I am unfortunately incorrect. Instead of the calculated 500kbps, I end up with 381.68kbps (measured by oscilloscope).
My setting for this is:
static const CANConfig cancfg = {
  CAN_MCR_ABOM | CAN_MCR_AWUM | CAN_MCR_TXFP,
  CAN_BTR_SJW(1) | CAN_BTR_TS2(1) | CAN_BTR_TS1(8) | CAN_BTR_BRP(10)
Where is my fault?
Re: Unsure about clock tree configuration (because the CANbus baud rate is not correct)
Posted: Thu Jan 30, 2025 12:45 pm
It is possible you have a wrong xtal frequency defined in board.h, your values are correct for a 12MHz xtal, do a review on your board files (there could be other wrong settings in there).
You should enable MCO and verify the frequency on the pin.
Posted: Thu Jan 30, 2025 12:59 pm
by KoF
Nope
#if !defined(STM32_HSECLK)
#define STM32_HSECLK                12000000U
Unfortunately, that's not the fault.
Surprisingly, the UARTS that have been put into operation in the meantime run at the correct baud rate via SD Driver
Posted: Thu Jan 30, 2025 3:11 pm
Then the error is in the CAN configuration or its input frequency, other clocks seem to be fine.
Posted: Fri Jan 31, 2025 8:47 pm
by alex31
Where is my fault?
Clock tree is indeed fine, but all the subfield CAN_BTR_SJW CAN_BTR_TS2 CAN_BTR_TS1 CAN_BTR_BRP have a minimum length of 1, so you must specify N-1 for all these fields c.a.d if you want a value of 1, you must specify 0 .
you should write this : CAN_BTR_SJW(0) | CAN_BTR_TS2(0) | CAN_BTR_TS1(7) | CAN_BTR_BRP(9)
since you have lengthened the tq, and you divide the clock source by 11 instead 10, you have lowered the bitrate.
hope this help.
Alexandre
