Update rp2040.h with latest SVD changes
Posted: Sun Dec 14, 2025 2:28 pm
by emulator
This proposed change updates the existing rp2040.h in main with the minimal SVD changes from the latest RP2040 SVD release. It does not add in the USB SRAM definitions yet as I'm seeking guidance whether there is a reason those are not in main.
diff --git a/os/common/ext/RP/RP2040/rp2040.h b/os/common/ext/RP/RP2040/rp2040.h
index c3919457e..c380089c1 100644
--- a/os/common/ext/RP/RP2040/rp2040.h
+++ b/os/common/ext/RP/RP2040/rp2040.h
@@ -116,7 +116,7 @@ typedef struct {
   __IO uint32_t         INTE0;
   __IO uint32_t         INTF0;
   __IO uint32_t         INTS0;
-  __I  uint32_t         resvd410;
+  __IO uint32_t         INTR1;
   __IO uint32_t         INTE1;
   __IO uint32_t         INTF1;
   __IO uint32_t         INTS1;
@@ -138,7 +138,7 @@ typedef struct {
@@ -161,7 +161,7 @@ typedef struct {
@@ -184,7 +184,7 @@ typedef struct {
