Small correction in hal_xsnor_base.c
Posted: Sun Feb 22, 2026 12:41 pm
chibios-code-r17707-trunk
Hi all,
compiling hal_xsnor_base.c gives below warning:
I think err should be initialized as shown below:
Best regards,
Wolf
Hi all,
Compiling hal_xsnor_base.c
../../chibios_trunk/os/hal/lib/complex/xsnor/src/hal_xsnor_base.c: In function 'xsnorStart':
../../chibios_trunk/os/hal/lib/complex/xsnor/src/hal_xsnor_base.c:909:10: warning: 'err' may be used uninitialized in this function [-Wmaybe-uninitialized]
909 | return err;
| ^~~Code: Select all
* @brief Configures and activates a SNOR driver.
* @param[in,out] ip Pointer to a @p hal_xsnor_base_c instance.
* @param[in] config Pointer to the configuration.
* @return An error code.
* @retval FLASH_NO_ERROR Operation successful.
* @retval FLASH_ERROR_HW_FAILURE If initialization failed.
* @api
flash_error_t xsnorStart(void *ip, const xsnor_config_t *config) {
hal_xsnor_base_c *self = (hal_xsnor_base_c *)ip;
flash_error_t err = FLASH_NO_ERROR;Wolf
