I've been exploring custom camera controller designs using the ESP32-S3 and OV5640 camera module. One interesting part of this design is that getting the camera working reliably involves more than connecting the data pins.
The camera interface requires proper coordination between the processor, power supplies, clock signals, and firmware configuration.
A few things worth paying attention to:
Power sequencing: The camera may require separate 2.8V and 1.5V supplies alongside the ESP32-S3's 3.3V rail. Their startup and enable signals should follow the camera's requirements.
Clock and synchronization: Signals such as XCLK, PCLK, HREF, and VSYNC need to be configured correctly for reliable image capture.
Data interface: The eight-bit DVP data bus (D0–D7) needs appropriate GPIO mapping and configuration.
PCB layout: Keep camera signal routing organized, provide good ground return paths, and place decoupling capacitors close to the relevant power pins.
Debugging: Accessible UART, boot, and reset connections make initial firmware testing much easier.[/list]
While looking into the hardware implementation, I came across a practical camera controller PCB design from PCBCool, a company specializing in PCB manufacturing and PCBA services, which explores these power, interface, and layout considerations.
I'm particularly interested in how developers approach the firmware side of camera integration.
A few questions for the ChibiOS community:
1. Has anyone worked with an ESP32-S3 camera interface using ChibiOS, particularly with an OV5640 or similar DVP sensor?
2. How do you typically handle camera initialization and power sequencing in your embedded firmware?
3. Do you prefer polling or interrupt/DMA-based approaches for handling continuous image data?
Would be interested to hear about your implementation experiences and any challenges you've encountered.
