Optimization level 1 and s do not work with STM32F051 demo
Hi there,
I am using the STM32F051-DISCOVERY example. I find that when setting optimization to level 1 or s, the demo does not run. The demo works find when optimization is set to 0 or 2.
I am guessing this is probably similar issue to previous problems caused by optimization (an exception occurs and the demo hangs). I haven't managed to get my debugger going on it, so I am just going by the state of the LEDs.
I using latest ChibiOS from the github master branch. Compiler is "(Sourcery G++ Lite 2011.03-42) 4.5.2".
Are there any ideas of how to resolve this? I would really like to use -Os in my project, there never seems to be enough Flash...
Cheers
Cheers
Re: Optimization level 1 and s do not work with STM32F051 de
Thanks for reporting, I found the problem in crt0.c. You can set CRT0_INIT_STACKS=0 as workaround, in the meanwhile I will open a ticket and handle this.
I think this is the cause of all the similar optimizations-related problems.
Does not help me.
Moving __early_init() call after stack initialization code too.
Looks like disabling FLASH_ACR_ICEN or FLASH_ACR_DCEN bits when initializing
flash access in hal_lld.c helps.
UPD:
That bits must be both disabled.
UPD:
You are right, __early_init() must be moved too, I don't understand the issue with those bits, doing so kills the MCU performance.
Giovanni wrote:doing so kills the MCU performance.
hm... for the first look performance does not affected at all.
But those bits should not affect anything, so it is possible you are masking the effect but there is another cause.
After moving __early_init() I don't see other problems in all demos I tested, let's wait some more feedback.
From stm32f4 errata:
Is it our problem?
2.1.1 ART Accelerator prefetch queue instruction is not supported
Description
The ART Accelerator prefetch queue instruction is not supported on revision A devices.
This limitation does not prevent the ART Accelerator from using the cache enable/disable
capability and the selection of the number of wait states according to the system frequency.
Workaround
Revision A devices: none
Revision Z devices: fixed.
Is it our problem?
Do you have a revision A device? I am not sure if the unit is simply not functional or if it should not be enabled at all.
