STM32F4 discovery use both usb otg interfaces
Posted: Fri Oct 26, 2012 10:12 am
by GZUnbekannt
Hello Chibios-Community ;)
I'm currently trying to make use of the second usb OTG interface of the stm controller.
The slower (full speed) should be used as a virtual com port, the faster one as a usb-memory interface.
Is there already an implementation of the second interface?
I'm using chibios 2.5.2 from svn ;)
Looking forward for replays :)
Greetings ;)
Re: STM32F4 discovery use both usb otg interfaces
Posted: Fri Oct 26, 2012 1:36 pm
Both are supported, but OTG HS is only supported in FS mode, the HS mode has never been tested because it requires an external PHY and probably a custom board.
Posted: Fri Oct 26, 2012 2:45 pm
by GZUnbekannt
Thank you for your fast replay!
Ok, i wanted to use one as Host and one for the serial interface, but okay, i've to go another way ;)
Greetings GZUnbekannt :)
