Page 1 of 2
FatFS performance
Posted: Mon Nov 12, 2012 4:41 am
by iggarpe
Hi all,
I'm using ChibiOS 2.4.x and the included patched FatFS library on a STM32F407V based board in which I have a microSD card connected to SPI1, and I'm quite disappointed with the write performance. I've implemented a few benchmark tests and these are the results:
Raw read/write (using the MMC driver sequential read/write functions):
Read: ~1700 KB/s
Write: ~1500 KB/s
File read/write (using FatFS):
Read: ~750 KB/S
Write: ~80 KB/S (!!!)
Now, I know there are mechanisms in a file system implementation that will inherently reduce the I/O performance, from cluster table maintenance to non-sequential read/write, but to me a slowdown from 1500 to 80 KB/s is a bit surprising, isn't it?
Re: FatFS performance
Posted: Mon Nov 12, 2012 8:07 am
by mabl
Do you read each byte separately? There is a nice benchmark by elm chan:
Posted: Mon Nov 12, 2012 1:31 pm
by Tectu
Can you show us your benchmarking code?
Posted: Mon Nov 12, 2012 1:54 pm
by iggarpe
Sure, I did not cut&paste it because it's pretty much trivial:
Raw MMC read benchmark:
    chprintf(chp, "Reading %u sectors starting at sector %u\r\n", count, sector);
    start = chTimeNow();
    if (mmcStartSequentialRead(&MMCD1, sector)) {
      chprintf(chp, "ERROR: cannot start sequential read\r\n");
      return 1;
    for (; count > 0; count--, size += MMC_SECTOR_SIZE)
      mmcSequentialRead(&MMCD1, (uint8_t *)shell_buf);
    if (mmcStopSequentialRead(&MMCD1)) {
      chprintf(chp, "ERROR: cannot stop sequential read\r\n");
      return 1;
    elapsed = chTimeNow() - start;
Raw MMC write benchmark:
    chprintf(chp, "Writing %u sectors starting at sector %u\r\n", count, sector);
    memset(shell_buf, value, MMC_SECTOR_SIZE);
    if (mmcStartSequentialWrite(&MMCD1, sector)) {
      chprintf(chp, "ERROR: cannot start sequential write\r\n");
      return 1;
      mmcSequentialWrite(&MMCD1, (uint8_t *)shell_buf);
    if (mmcStopSequentialWrite(&MMCD1)) {
      chprintf(chp, "ERROR: cannot stop sequential write\r\n");
      return 1;
File read benchmark:
    chprintf(chp, "Reading from file '%s'\r\n", argv[1]);
    res = f_open(&fil, argv[1], FA_READ | FA_OPEN_EXISTING);
    if (res != FR_OK) {
      chprintf(chp, "ERROR opening: %s\r\n", fss_strerr(res));
      return 1;
    for (;; size += len) {
      res = f_read(&fil, shell_buf, MMC_SECTOR_SIZE, &len);
      if (res != FR_OK) {
        chprintf(chp, "ERROR reading: %s\r\n", fss_strerr(res));
        f_close(&fil);
        return 1;
      if (len == 0) break;
    f_close(&fil);
File write benchmark:
    chprintf(chp, "Writing %u bytes 0x%.2x to file '%s'\r\n", count, value, argv[1]);
    res = f_open(&fil, argv[1], FA_WRITE | FA_OPEN_ALWAYS);
    if (res != FR_OK) {
      return 1;
    for (;; count -= len, size += len) {
      len = count;
      if (len > MMC_SECTOR_SIZE)
        len = MMC_SECTOR_SIZE;
      res = f_write(&fil, shell_buf, len, &len);
      if (res != FR_OK) {
        chprintf(chp, "ERROR writing: %s\r\n", fss_strerr(res));
        f_close(&fil);
        return 1;
    f_close(&fil);
Posted: Mon Nov 12, 2012 2:01 pm
by Tectu
I am currently on the road and therefore can not properly check your code, but I will try this out tonight for you so I can give you a few reference results ;-)
Posted: Tue Nov 13, 2012 6:43 pm
by iggarpe
No one has any performance figures ?
Posted: Wed Nov 14, 2012 11:36 am
by Abhishek
Hello iggarpe,
A few months ago I used a SD card connected to SPI1 of a Discovery board to display images on a LCD screen, I can only provide read figures.
It takes about 20081596 cycles or about 120ms (~8.4 fps) for a full screen image of , running on a F4Discovery @ 168MHz with a 2048 byte read buffer. The image size is 150 KB exactly. So with that it comes to be around 1.22 MB/s. When I used a larger buffer of size 16 KB, it went to 16007733 clock cycles (95 ms, 10.5 fps). This gives the read speed to be 1.54 MB/s . Note that this test has been done with ChibiOS 2.4.1, latest ChibiOS versions have a newer 'block device' implementation, I have not played around with that. The speed varies a lot depending on the SD card being tested and the compiler being used, the optimizations applied.
The read speed seems to depend a lot on the size of the read buffer, and whether the read you are doing is sector aligned (with a multiple of 512) or not. Even a misalignment of 1 byte causes a very significant loss of speed.
You could try increasing the read buffer size and see if it leads to any performance improvement.
Best Regards
Abhishek
Posted: Wed Nov 14, 2012 2:15 pm
by Prof. Dr. YoMan
I guess the problem is not the read speed. Which seems ok for him, but ...
Posted: Wed Nov 14, 2012 4:16 pm
by mabl
On the other hand, the Write performance does only depend on the card - the SPI data rate should be the same for both directions, shouldn't it? And given that it only shows with fatfs - maybe the FAT is not aligned or something? Or try another card?
Posted: Wed Nov 14, 2012 4:20 pm
The problem I see is that, unless I am missing something, FatFS does not have a proper buffers cache so it has to read/write FAT sectors continuously while performing a large sequential write.
