2.3.x development branch
Posted: Sun Mar 06, 2011 4:02 pm
ChibiOS/RT 2.3.0 has been released. This release is the start of the new development branch. Among the other features this version brings official support for USB and improvements to the kernel.
Worth mentioning are also the new "IRQ STORM" test applications under ./testhal, those really brings down the system on its knees in order to test overall stability, I must say the results have been very good, even under the worst conditions the system is able to recover (and by worst I mean random interrupts with an average period under 10uS and complete CPU saturation). The tests are meant to be long duration stress tests and take hours to complete.
List of changes:
*** 2.3.0 ***
- FIX: Fixed race condition in CM0 ports, the fix also improves the
ISR latency (bug 3193062)(backported to 2.2.2).
- FIX: Fixed Cortex-Mx linker scripts alignment of __heap_base__, the
correct alignment is now enforced at runtime into core_init() in order
to make the OS integration easier (bug 3191112)(backported to 2.2.2).
- FIX: Fixed error in function chCoreAllocI() function documentation (bug
3191107)(backported to 2.2.2).
- FIX: Fixed minor problem with memory pools (bug 3190512)(backported to
2.2.2).
- FIX: Stack overflow in CM0 ports when nearing interrupts saturation (bug
3187105)(backported to 2.2.1).
- FIX: Fixed error in _BSEMAPHORE_DATA macro (bug 3184139)(backported to
2.2.1).
- FIX: Error in MAC driver (bug 3179783)(backported to 2.2.1).
- FIX: Fixed wrong serial driver macros (bug 3173336)(backported to 2.2.1).
- NEW: Inproved preemption implementation for the Cortex-M0, now it uses
the NMI vector in order to restore the original context. The change makes
IRQ handling faster and also saves some RAM/ROM space. The GCC port code
now does not inline the epilogue code in each ISR saving significan ROM
space for each interrupt handler in the system (backported to 2.2.3).
- NEW: Added "IRQ STORM" long duration tests for the STM32, LPC11xx and
LPC11xx. The test demonstrates the system stability in a thread-intensive,
progressively CPU-saturating, IRQ-intensive long duration test.
- NEW: Added two new functions to the events subsystem: chEvtBroadcastFlags()
and chEvtBroadcastFlagsI(). The old chEvtBroadcast() and chEvtBroadcastI()
become macros. The new functions allow to add the same flags to all the
registered listener threads.
- NEW: Added I-Class functions to the MailBoxes subsystem, now it is
possible to use them as a transport layer between ISRs and Threads
- NEW: Added new USB driver model, probably it will evolve in next
releases.
- NEW: USB driver implementation for STM32.
- NEW: Added "serial over USB" driver, it implements a Communication
Device Class exposing it as a normal serial driver to applications,
probably it will evolve in next releases.
- NEW: Added STM32 USB CDC loopback test application.
- NEW: Added new GPT driver model, General Purpose Timer. The driver
allows to access the available timers in an abstract way.
- NEW: GTP driver implementation for STM32, LPC13xx and LPC11xx.
- NEW: Added STM32 GPT test application.
- NEW: Implemented new event IO_TRANSMISSION_END in the generic serial
driver. This event marks the physical transmission end of a data stream.
- NEW: Implemented the new IO_TRANSMISSION_END event in the STM32 serial
driver.
- NEW: Added explicit reset of all peripherals inside the STM32 HAL driver.
Removed the separate resets on initialization from the various other
drivers saving significant space.
- OPT: Removed TIMx reset on system startup in the STM32 PWM driver, the
timers are already reset on driver startup.
- CHANGE: The functions chEvtSignal() and chEvtSignalI() have been renamed
to chEvtSignalFlags() and chEvtSignalFlagsI() for consistency.
- CHANGE: Swapped the numeric values of the TIME_IMMEDIATE and TIME_INFINITE
constants. Fixed the relative documentation in various places (backported
to 2.2.2).
- Many documentation improvements.
As you can see, some of the new features have been, or are going to be, back-ported into the 2.2.x stable branch.
Re: 2.3.x development branch
Posted: Sun Apr 03, 2011 1:09 pm
ChibiOS/RT 2.3.1 has been released. This version brings numerous improvements to the Kernel and the HAL, a new ICU (Input Capture Unit) device driver model has been introduced.
Changes:
*** 2.3.1 ***
- FIX: Fixed insufficient idle thread stack in Cortex-M0-GCC port (bug 3226671)
- FIX: Fixed stack checking in Cortex-M0-GCC port (bug 3226657)(backported
to 2.2.3).
- FIX: Fixed wrong checks in PAL driver (bug 3224681)(backported to 2.2.3).
- FIX: Fixed wrong checks in I/O Queues (bug 3219197)(backported to 2.2.3).
- FIX: Fixed invalid assertion in adcConvert() (bug 3205410)(backported
to 2.2.3).
- NEW: Improvements to the PWM driver model:
- Easier configuration similar to the GPT driver initializations, macros
are no more required.
- Added a new function that allows to change the PWM period on the fly,
even from within callbacks. Formerly it was required to stop and restart
the driver.
- Improved driver documentation.
- NEW: Added advanced mode to the STM32 PWM driver (TIM1 only).
- NEW: Added new ICU driver model, Input Capture Unit.
- NEW: ICU driver implementation for STM32.
- NEW: Implemented stack checking in the Cortex-Mx RVCT port (backported
to 2.2.3).
- NEW: Added support for PLL3 in STM32 HAL driver. Note, the format of the
mcuconf.h file is changed for STM32F105/STM32F107 devices.
- NEW: Added board files for the Olimex STM32-P107.
- NEW: Improved setup packets handling in the USB driver through a specific
callback.
- NEW: Improvements to the PAL driver and various implementation in order
to make them more parenthesis friendly.
- OPT: Simplified Serial over USB driver configuration.
- CHANGE: Renamed the demo ARMCM3-STM32F107-GCC in ARMCM3-STM32F107 and added
IAR and Keil projects.
- CHANGE: Now the ARMCM3-STM32F107 demo targets the board Olimex STM32-P107
as default.
- CHANGE: Removed all the prefixes from the structure/union field names
in the HAL subsystem.
- CHANGE: Updated the documentation to use Doxygen 1.7.4 which produces a much
more readable output. Also modified the documentation layout to put functions
and variables ahead of everything else in the group pages.
Doxygen version below 1.7.4 cannot be used anymore because differences in
templates. Note that now there are two Doxygen projects, one for generating
the CHM file the other for plain HTML.
Posted: Sat May 14, 2011 10:40 am
ChibiOS/RT 2.3.2 has been released. A new SDC (Secure Digital Card) device driver model has been introduced among several other improvements and fixes.
Changes:
*** 2.3.2 ***
- FIX: Fixed invalid BRR() macro in AVR serial driver (bug 3299306)(backported
to 2.2.4).
- FIX: Fixed missing IRQ vectors amicable names for STM32 XL devices (bug
3298889)(backported to 2.2.4).
- FIX: Fixed wrong identifier in AVR serial driver (bug 3292084)(backported
to 2.2.4).
- FIX: Fixed wrong macro check for STM32 XL devices (bug 3291898)(backported
to 2.2.4).
- FIX: Fixed SPI driver restart in STM32 SPI driver implementation, also
applied the same fix to the STM8S SPI driver (bug 3288758)(backported to
2.2.4).
- FIX: Fixed missing state transition in ADC driver (bug 3288149)(backported
to 2.2.4).
- FIX: Fixed missing state transition in SPI driver (bug 3288112)(backported
to 2.2.4).
- FIX: Fixed spurious characters generated by Serial over USB driver (bug
3276379).
- NEW: Added an option to the kernel to not spawn the Idle Thread from within
chSysInit(), this way the application can spawn a custom idle thread or
even use the main() thread as idle thread (backported to 2.2.4).
- NEW: Added new SDC driver model, Secure Digital Card.
- NEW: SDC driver implementation for STM32.
- NEW: Updated the STM32 header file to the latest version 3.4.0, had to
fix a bug regarding the STM32 XL sub-family.
- NEW: New unified GCC startup file for Cortex-Mx processors, it is written
in C instead of asm and supports constructors/destructors. Improved the
Cortex-Mx linker scripts in all the GCC demos.
- NEW: Now it is possible to share DMA channels in the STM32 HAL thanks
to a centralized manager. Channels are allocated when the driver is
started and released when it is stopped.
- NEW: Added an STM32 C++ demo for the GNU compiler.
- NEW: Added an STM32F103ZG demo for the STM3210E-EVAL evaluation board.
Posted: Sun Oct 02, 2011 3:20 pm
ChibiOS/RT 2.3.3 has been released. The change log is huge:
*** 2.3.3 ***
- FIX: Fixed uninitialized variable in STM32 PWM and ICU drivers (bug 3413558).
- FIX: Fixed wrong parameter passed to the DMA error hook in STM32 ADC driver,
the DMA error hook has been removed entirely in the new ADC driver model
(bug 3413214)(to be fixed in 2.2.8).
- FIX: The function chThdExit() triggers an error on shell return when the
system state checker is enabled (bug 3411207)(backported to 2.2.8).
- FIX: Some ARMCMx makefiles refer the file rules.mk in the ARM7 port (bug
3411180)(backported to 2.2.8).
- FIX: Fixed wrong check on CH_DBG_ENABLE_STACK_CHECK setting (bug 3387671)
(backported to 2.2.7).
- FIX: Fixed wrong APB1 frequency check (bug 3361039)(backported to 2.2.7).
- FIX: Fixed missing state in shell demos (bug 3351556)(backported to 2.2.7).
- FIX: Fixed race condition in Cortex-Mx ports (bug 3317500)(backported
to 2.2.6).
- FIX: Fixed wrong macro check in STM32 UART driver (bug 3311999)(backported
to 2.2.6).
- FIX: Fixed wrong macro definition in ARMv6-M architecture files (bug
3310084).
- FIX: Fixed race condition in output queues (bug 3303908)(backported
to 2.2.4).
- FIX: Fixed CH_USE_HEAP and CH_USE_MALLOC_HEAP conflict (bug 3303841)
- FIX: Fixed timeout problem in the lwIP interface layer (bug 3302420)
- NEW: Added AVR implementation of the PAL driver contributed by Leszek.
(TODO: Update demos to use it)
- NEW: STM32L ADC driver implementation.
- NEW: Improved ADC driver model, now it is possible to handle error
conditions during the conversion process.
- NEW: STM32L1xx sub-family support, all STM32 drivers adapted and re-tested
on the new platform except ADC that will need a specific implementation.
- NEW: Added new API chThdExitS() in order to allow atomic operations on
thead exit (backported to 2.2.8).
- NEW: New EXT driver model and STM32 implementation.
- NEW: New I2C driver model and STM32 implementation.
(evaluate the option to change the API to a synchronous model)
- NEW: New RTC driver model and STM32 implementation.
(API and functionality review)
- NEW: Improved MAC driver model, it now follows the same template of other
drivers.
(TODO: uIP demo to be adapted)
(TODO: implement macStop() in AT91SAM7X implementation)
- NEW: New RCC helper driver for STM32F1xx and STM32L1xx, it simplifies
the use of the RCC resources and hides most differences found among the
various STM32 sub-families.
- NEW: New DMA helper driver for STM32, it simplifies the use of the DMA
resources and hides most differences with the new enhanced DMA units
found in the STM32F2xx sub-family.
- NEW: Now an error is generated at compile time when trying to enable the
options CH_DBG_ENABLE_STACK_CHECK on ports that do not support it.
- NEW: Added a kernel-only Cortex-Mx demo as reference project for users not
interested in the HAL but just want to use the ChibiOS/RT kernel.
The demo is named ARMCM3-GENERIC-KERNEL and is defaulted to the STM32, in
order to use it on other families or on the ARM Cortex-M0 just change the
inclusion paths in the makefile.
- NEW: Integrated new FatFs version 0.8b.
- NEW: Added a new hook THREAD_CONTEXT_SWITCH_HOOK() that allows to insert
code just before a context switch. For example this hook could be used
in oder to implement advanced power management schemes.
- NEW: Added a new debug option CH_DBG_SYSTEM_STATE_CHECK that ensures the
correct API call protocol. If an API is invoked out of the correct context
then the kernel panics with a debug message.
- NEW: Added Eclipse ChibiOS/RT debugger plugin 1.0.5 under ./tools/eclipse.
- NEW: The ARMCMx startup file (crt0.c) now is able to fill the stack areas
with a filler (default behavior). This is required in order to easily assess
the stack usage at runtime.
- NEW: Added the new CMSIS 2.1 headers, now CMSIS resides into a shared
location: ./os/ports/common/ARMCMx/CMSIS. Old CMSIS files have been
removed from the various platforms.
- NEW: Removed all the ch.ld files from the ARMCMx demos, now the makefiles
point to common ld files under the various ports. Less duplication and
easier maintenance.
- NEW: Improved stack checking and reorganized memory map for the Cortex-Mx
demos. Now stacks are allocated at the start of the RAM, an overflow of the
exception stack now triggers an exception (it could go unnoticed before).
The process stack is organized to be checked on context switch like other
threads. Now all threads have an explicit stack boundary pointer.
- NEW: Added debug plugin for Eclipse under ./tools/eclipse (backported to
2.2.7).
- NEW: The debug macros chDbgCheck() and chDbgAssert() now can be externally
redefined. The macro chDbgCheck() no more includes the line number in the
description because incompatibility with the Cosmic compiler (backported to
2.2.7).
- NEW: Added provisional support for STM32F2xx. Because of this some
directories related to the STM32 have been renamed, your makefiles may
require adjustments.
- NEW: Added a custom rule to the various rules.mk files, now it is possible
to add an user rule into the Makefiles.
- NEW: Improvements to the trace buffer, now it stores a full thread pointer
and event time, changed names to debug variables by adding the "dbg_"
prefix (backported to 2.2.7).
- NEW: Added a new functionality to the registry subsystem, now it is possible
to associate a name to the threads using chRegSetThreadName. The main and
idle threads have their name assigned by default (backported to 2.2.7).
- NEW: Added TIM8 support to the STM32 GPT, ICU and PWM drivers.
- NEW: Updated the STM32 header file to the latest version 3.5.0 and fixed
it in order to correct several bugs related to the XL family.
- NEW: Added a chprintf() function to ./os/various, it can print on any
BaseChannel.
- NEW: Improved the mini shell, enhanced info command, optimizations and
removed the shellPrint() and shellPrintLine() functions, now it uses
chprintf() for output.
- NEW: lwIP 1.4.0 has been integrated, this new version does not require
custom hooks into the Thread structure and is thus much lighter.
- NEW: FatFs demo for the STM32F103ZG using the SDC driver.
- NEW: Now the STM32 SDC driver supports unaligned buffers transparently.
Optimized the driver for single block read and write operations. Optimized
the driver state machine.
- NEW: Finished the reorganization of the Cortex-Mx ports, now also the
IAR and RVCT ports support the new Compact mode.
- NEW: Added to the ARMv6-M sub-port an option to use the PendSV exception
instead of NMI for preemption (backported to 2.2.5).
- NEW: Reorganization of the Cortex-Mx ports in order to reduced code and
comments duplication in the various headers (backported to 2.2.5).
- NEW: Improved the ARMv7-M sub-port now there are two modes: Compact and
Advanced.
The advanced mode is equivalent to the previous versions, the compact mode
is new and makes the kernel *much* smaller and generally faster but does
not support fast interrupts (backported to 2.2.5).
- NEW: Now the port layer exports info regarding the compiler and the port
options. The info are printed into the test reports. Date and time also
added.
- CHANGE: Removed the option CH_USE_NESTED_LOCK, lwIP no more requires it and
it would have conflicted with CH_DBG_SYSTEM_STATE_CHECK which is far more
useful.
- CHANGE: Renamed the scheduler functions chSchIsRescRequiredExI() to
chSchIsPreemptionRequired(), chSchDoRescheduleI() to chSchDoReschedule(),
chSysSwitchI() to chSysSwitch(). All those functions were special cases
and not regular I-class APIs.
- CHANGE: Renamed the macros IDLE_THREAD_STACK_SIZE and INT_REQUIRED_STACK
to PORT_IDLE_THREAD_STACK_SIZE and PORT_INT_REQUIRED_STACK for consistency.
- CHANGE: Removed the "old" Cortex-M3 port from the code, the current port
has no drawbacks and the old port is now just a maintenance cost.
- CHANGE: Removed the CH_CURRP_REGISTER_CACHE option, it is GCC-specific so
it does not belong to the kernel options. The feature will be eventually
reimplemented as a port-specific option.
- CHANGE: chiQGetFullI() and chOQGetFullI() become macros. The queues
subsystem has been optimized and is no more dependent on semaphores.
Note that the queues callbacks invocation policy has been slightly
changed, see the documentation (backported to 2.2.4).
I need to finalize the next stable branch 2.4.x so no new features will be added to 2.3.3, only fixes and improvements to the existing codebase (except eventually for minor things).
Posted: Sun Nov 27, 2011 10:44 am
ChibiOS/RT 2.3.4 has been released. Lots of improvements and new features in this version:
*** 2.3.4 ***
- FIX: Fixed Extra initialization in STM32 SPI driver (bug 3436127)
- FIX: Fixed DMA priority setting error in STM32 UART driver (bug 3436125)
- FIX: Fixed DMA priority setting error in STM32 SPI driver (bug 3436124)
- FIX: Fixed broken support for UART5 in STM32 serial driver (bug 3434094)
- FIX: Fixed broken TIM8 support in STM32 PWM driver (bug 3418620).
- FIX: Fixed halconf.h file corrupted in some STM32 demos (bug 3418626).
- NEW: Added an unified registers file for STM32: stm32.h. This file includes
the appropriate vendor file then adds its own additional definitions.
- NEW: Added demo for the ST STM32F4-Discovery kit.
- NEW: STM32F4xx ADC driver implementation.
- NEW: Added initialization of the NVIC VTOR register to all Cortex-Mx (v7M)
ports. Also added a port option CORTEX_VTOR_INIT to enforce a different
default value into the register.
- NEW: Removed the warning about the "untested M4 platform", now it is
tested and officially supported.
- NEW: Reorganized the STM32F1xx hal_lld_xxx.h files in order to distribute
the capability macros into the appropriate file (previously those were all
in the common hal_lld.h).
- NEW: Added HAL, Serial, ADC, EXT, GPT, ICU, PWM, SPI and UART support for
the STM32F4xx sub-family.
TODO: Add CAN and SDC, the drivers need to be ported and tested.
- NEW: Added handling of USART6 to the STM32 serial driver.
- NEW: Added USE_COPT setting to all makefiles, contributed by Mabl.
- NEW: Added EXT driver implementation for AT91SAM7x, contributed by Florian.
TODO: Test application missing.
- NEW: Updated USB driver model and STM32 implementation and fixed several
problems.
- Changed the API to move buffer copy operations out of critical zones.
- Added usbConnectBus() and usbDisconnectBus() functions.
- Fixed problems with incorrect assertions.
- NEW Updated the SERIAL_USB driver to match the new USB API, also fixed
some problems.
- Fixed incorrect use of input queues, the change required a change in
input queues too.
- NEW: Added a macro THD_STATE_NAMES to chthreads.h. This macro is an
initializer for string arrays containing thread state names.
- NEW: Added memory copy functionality to the STM32 DMA driver.
- NEW: Implemented new makefile system for ARM GCC ports, now objects,
listings and output files are generated into a "build" directory and not
together with sources, also implemented a simplified output log mode.
Now makefiles and load script files are requirements and trigger a
rebuild if touched.
- NEW: Updated AVR demos to use the new PAL driver.
- NEW: Added Keil build files to the STM32L-Discovery demo.
- CHANGE: Now the callback associated to input queues is invoked before
reading each character. Previously it was invoked only before going
to sleep into the THD_STATE_WTQUEUE state.
- CHANGE: Moved the STM32 DMA helper drivers files under the sub-family
specific directories because documentation issues.
