Problem with PWM
oattao
Problem with PWM
Post by oattao »
I have a STM32L-Discovery kit. I want to control the brightness of Led4 (connect with pin PB6). I used this code:
#include "ch.h"
static PWMConfig pwmcfg = {
  10000,                                    /* 10kHz PWM clock frequency.   */
  10000,                                    /* Initial PWM period 1S.       */
  NULL,
   {PWM_OUTPUT_ACTIVE_HIGH, NULL},
   {PWM_OUTPUT_DISABLED, NULL},
  0,
int main(void) {
  pwmStart(&PWMD2, &pwmcfg);
  palSetPadMode(GPIOB, 6, PAL_STM32_MODE_OUTPUT);
  chThdSleepMilliseconds(2000);
  //  PWM channel 0 to 50% duty cycle.
  pwmEnableChannel(&PWMD2, 0, PWM_PERCENTAGE_TO_WIDTH(&PWMD2, 5000));
  while (TRUE) {
But it doesn't work. Led4 is off. What's wrong with my code?
Please help me. Thanks in advance.
Re: Problem with PWM
The problem is that you programmed the pin as output instead of alternate(n), look into the DISCOVERY-MEMS demo, there is an example about setting up LED pins as PWM outputs.
oattao
Post by oattao »
Giovanni, thank you very much. I can solve problem now. :D
