SPI configuration in STM32f4 discovery demo
Posted: Sat Jan 26, 2013 10:41 pm
by Faisal Mehmood
Hey all
I have some problem with the following line of spi1cfg portion of STM32F4 discovery demo code:
SPI_CR1_BR_0 | SPI_CR1_BR_1 | SPI_CR1_CPOL | SPI_CR1_CPHA
I went through the STMF4xx reference manual and also read the stm32f4xx.h file in hal folder of OS directory. I can't understand how the configuration bits of the SPICONFIG structure determine the 5.25Mhz baudrate of SPI1 while according to the reference manual, those settings mean:
SPI_CR1_BR_0 = 1
SPI_CR1_BR_1 = 1 - - - - - - - } BR[2:0] = 011 => Baudrate = fclk/256 = 168Mega/256 = 656.2 KHz
SPI_CR1_BR_2 = 0
may be i misunderstood the bit configurations :roll:
Kindly tell me where the problem is
Re: SPI configuration in STM32f4 discovery demo
Posted: Sun Jan 27, 2013 1:13 am
by Tectu
Where exactly do you get the 5.25MHz from? Is that written somewhere? Also, I just checked the F4-Discovery demo code and no SPI1 is used? Only SPI2 is used with the max. speed.
Posted: Sun Jan 27, 2013 1:42 pm
by Faisal Mehmood
guess both spi1 nd spi2 are being used
5.25Mhz is stated in the comments:
 * SPI1 configuration structure.
 * Speed 5.25MHz, CPHA=1, CPOL=1, 8bits frames, MSb transmitted first.
 * The slave select line is the pin GPIOE_CS_SPI on the port GPIOE.
static const SPIConfig spi1cfg = {
  NULL,
  /* HW dependent part.*/
  GPIOE,
  GPIOE_CS_SPI,
 * SPI2 configuration structure.
 * Speed 21MHz, CPHA=0, CPOL=0, 16bits frames, MSb transmitted first.
 * The slave select line is the pin 12 on the port GPIOA.
static const SPIConfig spi2cfg = {
  spicb,
  GPIOB,
  12,
  SPI_CR1_DFF
Posted: Sun Jan 27, 2013 6:51 pm
by etmatrix
Faisal Mehmood wrote:may be i misunderstood the bit configurations :roll:
For configure speed in SPI I use the follow define
// Peripherial Clock 42MHz SPI2 SPI3
// Peripherial Clock 84MHz SPI1                                SPI1        SPI2/3
#define SPI_BaudRatePrescaler_2         ((uint16_t)0x0000) //  42 MHz      21 MHZ
#define SPI_BaudRatePrescaler_4         ((uint16_t)0x0008) //  21 MHz      10.5 MHz
#define SPI_BaudRatePrescaler_8         ((uint16_t)0x0010) //  10.5 MHz    5.25 MHz
#define SPI_BaudRatePrescaler_16        ((uint16_t)0x0018) //  5.25 MHz    2.626 MHz
#define SPI_BaudRatePrescaler_32        ((uint16_t)0x0020) //  2.626 MHz   1.3125 MHz
#define SPI_BaudRatePrescaler_64        ((uint16_t)0x0028) //  1.3125 MHz  656.25 KHz
#define SPI_BaudRatePrescaler_128       ((uint16_t)0x0030) //  656.25 KHz  328.125 KHz
#define SPI_BaudRatePrescaler_256       ((uint16_t)0x0038) //  328.125 KHz 164.06 KHz
static const SPIConfig spicfg = { NULL, TP_CS_PORT, TP_CS_PIN, SPI_BaudRatePrescaler_32 };
I tried to understand the reference manual, but for me is not explained well in that section. So I have found these defines in ST Library and I use always these for my projects.
Posted: Sun Jan 27, 2013 7:53 pm
by Faisal Mehmood
Thanx for the replies guys I guess I now know what the problems were:
1) I assumed SPI1 peripheral clock to be 168Mhz while actually its 84Mhz
2) BR[2:0] = 011 means the peripheral clock will be divided by 16, not 256 as i thought previously... clock is divided by 256 when BR[2:0] = 111
Thanx again guys!
Posted: Sun Jan 27, 2013 8:44 pm
Better add similar definitions directly to the SPI driver. Sorry for being late but I was in travel and the mobile worked intermittently.
Posted: Sun Jan 27, 2013 10:38 pm
by Tectu
I fully agree that your settings would result in a prescaler of 16. Sorry that I didn't tell you that but I didn't clearly look at your code, since I am still searching the part where the STM32F407 Discovery demo does use SPI1...
I would have loved to help here but I was too confused about where SPI1 is in the STM32F4 Discovery demo code? Can anybody please lead me to the light? :D
Posted: Mon Jan 28, 2013 5:25 pm
by Faisal Mehmood
@ Tectu you might have downloaded another file :)
here in the main.c file of STM32F4 Discovery demo code:
    ChibiOS/RT - Copyright (C) 2006,2007,2008,2009,2010,
                 2011,2012 Giovanni Di Sirio.
    This file is part of ChibiOS/RT.
    ChibiOS/RT is free software; you can redistribute it and/or modify
    it under the terms of the GNU General Public License as published by
    the Free Software Foundation; either version 3 of the License, or
    (at your option) any later version.
    ChibiOS/RT is distributed in the hope that it will be useful,
    but WITHOUT ANY WARRANTY; without even the implied warranty of
    MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
    GNU General Public License for more details.
    You should have received a copy of the GNU General Public License
    along with this program.  If not, see <http://www.gnu.org/licenses/>.
    A special exception to the GPL can be applied should you wish to distribute
    a combined work that includes ChibiOS/RT, without being obliged to provide
    the source code for any proprietary components. See the file exception.txt
    for full details of how and when the exception can be applied.
#include "ch.h"
#include "hal.h"
#include "test.h"
#include "lis302dl.h"
#include "chprintf.h"
static void pwmpcb(PWMDriver *pwmp);
static void adccb(ADCDriver *adcp, adcsample_t *buffer, size_t n);
static void spicb(SPIDriver *spip);
/* Total number of channels to be sampled by a single ADC operation.*/
#define ADC_GRP1_NUM_CHANNELS   2
/* Depth of the conversion buffer, channels are sampled four times each.*/
#define ADC_GRP1_BUF_DEPTH      4
 * ADC samples buffer.
static adcsample_t samples[ADC_GRP1_NUM_CHANNELS * ADC_GRP1_BUF_DEPTH];
 * ADC conversion group.
 * Mode:        Linear buffer, 4 samples of 2 channels, SW triggered.
 * Channels:    IN11   (48 cycles sample time)
 *              Sensor (192 cycles sample time)
  FALSE,
  ADC_GRP1_NUM_CHANNELS,
  adccb,
  NULL,
  0,
  ADC_CR2_SWSTART,
  ADC_SMPR1_SMP_AN11(ADC_SAMPLE_56) | ADC_SMPR1_SMP_SENSOR(ADC_SAMPLE_144),
  0,
  ADC_SQR1_NUM_CH(ADC_GRP1_NUM_CHANNELS),
  0,
  ADC_SQR3_SQ2_N(ADC_CHANNEL_IN11) | ADC_SQR3_SQ1_N(ADC_CHANNEL_SENSOR)
 * PWM configuration structure.
 * Cyclic callback enabled, channels 1 and 4 enabled without callbacks,
 * the active state is a logic one.
static PWMConfig pwmcfg = {
  10000,                                    /* 10kHz PWM clock frequency.   */
  10000,                                    /* PWM period 1S (in ticks).    */
  pwmpcb,
    {PWM_OUTPUT_ACTIVE_HIGH, NULL},
    {PWM_OUTPUT_DISABLED, NULL},
  0
  NULL,
  GPIOE,
  GPIOE_CS_SPI,
  spicb,
  GPIOB,
  12,
  SPI_CR1_DFF
 * PWM cyclic callback.
 * A new ADC conversion is started.
static void pwmpcb(PWMDriver *pwmp) {
  (void)pwmp;
  /* Starts an asynchronous ADC conversion operation, the conversion
     will be executed in parallel to the current PWM cycle and will
     terminate before the next PWM cycle.*/
  chSysLockFromIsr();
  adcStartConversionI(&ADCD1, &adcgrpcfg, samples, ADC_GRP1_BUF_DEPTH);
  chSysUnlockFromIsr();
 * ADC end conversion callback.
 * The PWM channels are reprogrammed using the latest ADC samples.
 * The latest samples are transmitted into a single SPI transaction.
void adccb(ADCDriver *adcp, adcsample_t *buffer, size_t n) {
  (void) buffer; (void) n;
  /* Note, only in the ADC_COMPLETE state because the ADC driver fires an
     intermediate callback when the buffer is half full.*/
  if (adcp->state == ADC_COMPLETE) {
    adcsample_t avg_ch1, avg_ch2;
    /* Calculates the average values from the ADC samples.*/
    avg_ch1 = (samples[0] + samples[2] + samples[4] + samples[6]) / 4;
    avg_ch2 = (samples[1] + samples[3] + samples[5] + samples[7]) / 4;
    chSysLockFromIsr();
    /* Changes the channels pulse width, the change will be effective
       starting from the next cycle.*/
    pwmEnableChannelI(&PWMD4, 0, PWM_FRACTION_TO_WIDTH(&PWMD4, 4096, avg_ch1));
    pwmEnableChannelI(&PWMD4, 3, PWM_FRACTION_TO_WIDTH(&PWMD4, 4096, avg_ch2));
    /* SPI slave selection and transmission start.*/
    spiSelectI(&SPID2);
    spiStartSendI(&SPID2, ADC_GRP1_NUM_CHANNELS * ADC_GRP1_BUF_DEPTH, samples);
 * SPI end transfer callback.
static void spicb(SPIDriver *spip) {
  /* On transfer end just releases the slave select line.*/
  chSysLockFromIsr();
  spiUnselectI(spip);
 * This is a periodic thread that does absolutely nothing except flashing
 * a LED.
void static msg_t Thread1(void *arg) {
  (void)arg;
  while (TRUE) {
    palSetPad(GPIOD, GPIOD_LED3);       /* Orange.  */
    chThdSleepMilliseconds(500);
    palClearPad(GPIOD, GPIOD_LED3);     /* Orange.  */
 * Application entry point.
int main(void) {
   * System initializations.
   *   RTOS is active.
   * Activates the serial driver 2 using the driver default configuration.
   * PA2(TX) and PA3(RX) are routed to USART2.
  sdStart(&SD2, NULL);
  palSetPadMode(GPIOA, 2, PAL_MODE_ALTERNATE(7));
  palSetPadMode(GPIOA, 3, PAL_MODE_ALTERNATE(7));
   * If the user button is pressed after the reset then the test suite is
   * executed immediately before activating the various device drivers in
   * order to not alter the benchmark scores.
  if (palReadPad(GPIOA, GPIOA_BUTTON))
    TestThread(&SD2);
   * Initializes the SPI driver 2. The SPI2 signals are routed as follow:
   * PB12 - NSS.
   * PB13 - SCK.
   * PB14 - MISO.
   * PB15 - MOSI.
  spiStart(&SPID2, &spi2cfg);
  palSetPad(GPIOB, 12);
  palSetPadMode(GPIOB, 12, PAL_MODE_OUTPUT_PUSHPULL |
                           PAL_STM32_OSPEED_HIGHEST);           /* NSS.     */
  palSetPadMode(GPIOB, 13, PAL_MODE_ALTERNATE(5) |
                           PAL_STM32_OSPEED_HIGHEST);           /* SCK.     */
  palSetPadMode(GPIOB, 14, PAL_MODE_ALTERNATE(5));              /* MISO.    */
  palSetPadMode(GPIOB, 15, PAL_MODE_ALTERNATE(5) |
                           PAL_STM32_OSPEED_HIGHEST);           /* MOSI.    */
   * Initializes the ADC driver 1 and enable the thermal sensor.
   * The pin PC0 on the port GPIOC is programmed as analog input.
  adcStart(&ADCD1, NULL);
  adcSTM32EnableTSVREFE();
  palSetPadMode(GPIOC, 1, PAL_MODE_INPUT_ANALOG);
   * Initializes the PWM driver 4, routes the TIM4 outputs to the board LEDs.
  pwmStart(&PWMD4, &pwmcfg);
  palSetPadMode(GPIOD, GPIOD_LED4, PAL_MODE_ALTERNATE(2));  /* Green.   */
  palSetPadMode(GPIOD, GPIOD_LED6, PAL_MODE_ALTERNATE(2));  /* Blue.    */
   * Creates the example thread.
   * Initializes the SPI driver 1 in order to access the MEMS. The signals
   * are initialized in the board file.
   * Several LIS302DL registers are then initialized.
  spiStart(&SPID1, &spi1cfg);
  lis302dlWriteRegister(&SPID1, LIS302DL_CTRL_REG1, 0x43);
  lis302dlWriteRegister(&SPID1, LIS302DL_CTRL_REG2, 0x00);
  lis302dlWriteRegister(&SPID1, LIS302DL_CTRL_REG3, 0x00);
   * sleeping in a loop and check the button state, when the button is
   * pressed the test procedure is launched with output on the serial
   * driver 2.
  while (TRUE) {
    int8_t x, y, z;
      TestThread(&SD2);
    x = (int8_t)lis302dlReadRegister(&SPID1, LIS302DL_OUTX);
    y = (int8_t)lis302dlReadRegister(&SPID1, LIS302DL_OUTY);
    z = (int8_t)lis302dlReadRegister(&SPID1, LIS302DL_OUTZ);
    chprintf((BaseChannel *)&SD2, "%d, %d, %d\r\n", x, y, z);
Posted: Mon Jan 28, 2013 5:37 pm
by Tectu
You should have checked out the link I have posted... This is the STM32F407 Discovery code. It looks like you where talking about the STM32F407 MEMS Discovery code all the time...
Well, never mind then.
