send data between 2 threads
nupagachi85
Dear all,
Now I have 1 data like that:
typedef struct _MESSAGE
BYTE Type;
BYTE MsgId;
BYTE MsgIndex;
BYTE MsgSize;
} MESSAGE;
MESSAGE data;
How I send and recieve between 2 threads?
Thanks and best regards
BYTE Type;
BYTE MsgId;
BYTE MsgIndex;
BYTE MsgSize;
} MESSAGE;
MESSAGE data;
Re: send data between 2 threads
A common way to do this is using a mailbox / message queue. You might want to read this thread from the other day.
nupagachi85
But when I using maibox : msg_t chMBPost(Mailbox *mbp, msg_t msg, systime_t time);
It just support send msg_t = int32_t, but I want send struct, how can I do?
Best regards
Best regards
In ChibiOS there are two mechanisms usable for this kind of tasks:
1) Mailboxes as suggested by Tectu.
2) Messages.
The Mailboxes are mono-directional queues of messages, best suited when you just want to send a message and do not wait for reception.
Messages are synchronous instead, you send a message and then the thread wait until the message is processed and an answer returned to the sender.
2) Messages.
nupagachi85 wrote:Hi,
Best regards
I suggest you use messages, this way you can allocate your struct into an automatic variable of the sender. In case you want to use mailboxes you could use two mailboxes:
1) Mailbox 1 is used to store pointers to unused message structures.
2) Mailbox 2 is used to send messages.
The sender takes a structure from #1, fills it and then sends it on #2. The receiver takes the message from #2, processes it and then returns it on #1. You need to pre-fill #1 on initialization.
Best regards
Hi nupagachi85,
msg_t is guaranteed to be large enough to contain a pointer. So what you typically do for mailboxes, is to use a memory pool for your struct, and send only a pointer via messages. For synchronous messages, you do not even need the pool.
nupagachi85
thanks for reply.
My app have a data like that. It is a struct. I don't find any example show me do that. I just a Newbie with chibios.
Do you help me a short code how to send and recieve it?
Did you take a look at the thread I linked? There is a discussion and another link about a module using this technique.
There is a thread in the development regarding a FatFs wrapper that exchanges messages, you could use that for example.
@Giovanni: I just got in mind that both, the FatFSWrapper and ChibiOS/GFX do use one-way message queues.
