External Trigger for Timer on STM32F4-Discovery
Posted: Thu Feb 07, 2013 3:54 pm
by Fede
Hi all,
I'd like to start a timer each time a rising edge arrives on a pin, like a external trigger...
Do you know if is possible to set ChibiOS GPT for this application?
In generally, I know that is possible because there is an example project inside the STM32 Standard Peripherals Library that is called:
"TIM_ExtTrigger_Synchro"...
http://brawikov.narod.ru/StdPerLibSTM32F10x/group__TIM__ExtTrigger__Synchro.html
I know that is possible to set a EXT that calls an interrupt that starts a timer but I'd like to use directly the timer...
Thank you in advance...
Fede
PS (the test hardware is a STM32F4Discovery board)
Re: External Trigger for Timer on STM32F4-Discovery
Posted: Thu Feb 07, 2013 4:08 pm
The GPT driver does not support this scenario, it is meant to be an abstraction of periodic timers so it does not support STM32-specific timer features. You should consider a custom driver for that function or adding a small custom enhancement to the GPT low level driver.
Thread moved to support, this forum is meant for project announcements.
Posted: Thu Feb 07, 2013 4:40 pm
by Fede
I'm sorry... thank you Giovanni, I was already thinking about an enhancement of GPT low level driver...
if I will get results, I'll put them here.
Bye
Fede
