I'm porting ChibiosNIL currently to a special msp platform and running in some issues with the tickless mode. During a sleep the supplied time get compared against the CH_CFG_ST_TIMEDELTA variable and adjusted if the time is too short.
Now in the function chSysTimerHandlerI which gets called on a timer interval, the next value for another thread get calculated, but here it can be lower than CH_CFG_ST_TIMEDELTA. On my slow platform this leads to overflows in the timer because the capture value gets set lower than the current counter register. Is this a bug or am I using the whole system wrong
ty for your help
Used commit:
commit 55b0336818642ea4a350f58d979689015831440f
Author: tfateba <tfateba@35acf78f-673a-0410-8e92-d51de3d6d3f4>
Date: Fri Nov 4 23:36:20 2016 +0000
Add support for AVR, Arduino Mini board.
git-svn-id: svn://svn.code.sf.net/p/chibios/svn/trunk@9901 35acf78f-673a-0410-8e92-d51de3d6d3f4
