Hey
I want to run Chibios on my Olimnex SAM7H256 development board. However, there is no board.h or board.c file for this.
How should I go about implementing this?
SAM7H256
Re: SAM7H256
Hello arunarus,
I'm not into the SAM things at all, but the process is the same for all MCUs: In your case, it's recommended to take one of the two existing board files for the SAM7 boards of olimex, copy it, rename it and then simply modify the necessary things. I took a look at the olimex boads and it looks like the H256 board features exactly the same MCU as the P256. Therefore, I'd go with the P256 board files.
You my want to share your board files in the 'Contributions' section of this forum when you're done
