[DONE] I2C driver for STM32F0
goeck
Re: [DONE] I2C driver for STM32F0
Post by goeck »
Hey,
now using the new driver as well and having issues here. I have a STM32F0 Discovery connected to 4 of TMC222 motor motion controllers, which used to work fine with the I2Cv2 driver supplied earlier by doceme as a patch.
My point is, that if i use
i2cMasterTransmitTimeout(&I2CD1, addr>>1, command, txLength, buffer, rxLength, MS2ST(10));
I get the adress byte thrown on the line and ACKed, then the command byte also ACKed but then the SCL line keeps low, the SDA line gets high. Seemes like an endlessly streeetched clock cycle. I found, some Cypress PSoC had same issues, see here: http://www.cypress.com/?id=4&rID=38929.
No STOP contition is generated and my slaves can't supply an answer on the sent intend.
Help is greatly appreciated.
Cheers
Stefan
The only I2C device I can test on in this moment is an M24M01 EEPROM, whould be possible to simulate the problem using that?
Please post the parameter values for that transmit.
MartinP
Post by MartinP »
Hi Goeck,
Did you fix the missing DMA vectors?
in STM32F0xx\stm32_dma.c
you need to change the following:
Line 112: CH_IRQ_HANDLER(DMA1_Ch1_IRQHandler) --> CH_IRQ_HANDLER(Vector64)
Line 130: CH_IRQ_HANDLER(DMA1_Ch2_3_IRQHandler) --> CH_IRQ_HANDLER(Vector68)
Line 159: CH_IRQ_HANDLER(DMA1_Ch4_5_IRQHandler) --> CH_IRQ_HANDLER(Vector6C)
as the preprocessor definitions DMA1_Ch1_IRQHandler, DMA1_Ch2_3_IRQHandler, DMA1_Ch4_5_IRQHandler were deleted lately.
Martin
BTW, tomorrow I will fix the problem with vectors. Couldn't do that during the week.
goeck
Post by goeck »
Hey guys, sorry, no net connection during weekend. So here we go again. I saw the fix for bug #400, which adresses the DMA issue, right.
I didn't get any hints by the compiler or linker regarding interrupt vectors or similar...
Now I will try with the latest SVN code rev. 5591.
Also I found a screenshot laying around on my desktop which was generated by Saleae logic for the purpose of showing the result on the I2C lines.. hoping that this will disappear now, I still want to show off the behaviour I experienced last friday.
Thanks for the replies anyway.
Cheers
____EDIT1:
After using the mentioned SVN revision of code it freakin just works :-)
Thanks for alle the support again!
Keept it up.
Cheers
Stefan
Saleae Logic screenshot
steved
Has thanked: 12 times
Been thanked: 138 times
Post by steved »
In the course of finding some problems in my code, I had a closer look at some of the flow within the I2C driver. I'm not sufficiently familiar with the entrails of ChiboOS to say that there is definitely a problem, but there looked to be a couple of places where interrupts might cause some receive-related code to be executed twice. I've attached my modified driver in the hope that the experts might take a look.
I2Cv2.zip
(7.36 KiB) Downloaded 534 times
Thanks, there were some good points in the patch and I merged it, I also made some more changes. The driver appears to work stably and very well.
Just a not, please consider our coding conventions when submitting code http://www.chibios.org/dokuwiki/doku.ph ... tyle_guide this would make merging code easier.
DeusExMachina
Has thanked: 3 times
Been thanked: 3 times
Post by DeusExMachina »
I downloaded Chibios 2.6.2 version but I don't find i2c driver in ChibiOS_2.6.2\os\hal\platforms\STM32F0xx\
If drivers is stable, why it is absent in distribution?
goeck
Post by goeck »
Well, I think it's located in os/platforms/STM32/I2Cv2.
I guess that's because those drivers are common to more than one platform (in this case STM32F0xx), Giovanni, is that true?
Correct, most driver are under ./os/hal/platforms/STM32 because are shared among the various sub-families.
