I want to compile chibios for a stm32L151 microprocessor. I use is the last version from svn (trunk: revision 5591) of chibios.
I tried to run the ARMCM3-STM32L152-DISCOVERY demo project but after the fist context switch the eclipse debugger gave an error stack overflow. After this I changed the main.c code to:
/* * System initializations. * - HAL initialization, this also initializes the configured device drivers * and performs the board-specific initializations. * - Kernel initialization, the main() function becomes a thread and the * RTOS is active. */ halInit(); chSysInit();
while (TRUE) { chThdSleepMilliseconds(5); } }
sadly the fist time the program calls sleep. The debugger stops again with a stack overflow.
In mcuconf.h I disabled the LSE because my board does not have an external crystal.
One thing I noticed, is that after the call to the function chSysInit(). The chibios debugger plugin shows a stack overflow for the main thread. With a STM32F4 the eclipse plugin also shows a stack overflow for the main thread after chSysInit() but after the fist call to chThdSleepMilliseconds(5) the stkUnused is suddenly valid and the program does not stop.
I will look into this in the evening, did you try to increase the stack size for the main thread? also, what debug options do you have enabled in chconf.h?
/* ChibiOS/RT - Copyright (C) 2006-2013 Giovanni Di Sirio
Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except in compliance with the License. You may obtain a copy of the License at
Unless required by applicable law or agreed to in writing, software distributed under the License is distributed on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License for the specific language governing permissions and limitations under the License. */
/** * @file templates/chconf.h * @brief Configuration file template. * @details A copy of this file must be placed in each project directory, it * contains the application specific kernel settings. * * @addtogroup config * @details Kernel related settings and hooks. * @{ */
/** * @brief System tick frequency. * @details Frequency of the system timer that drives the system ticks. This * setting also defines the system tick time unit. */ #if !defined(CH_FREQUENCY) || defined(__DOXYGEN__) #define CH_FREQUENCY 1000 #endif
/** * @brief Round robin interval. * @details This constant is the number of system ticks allowed for the * threads before preemption occurs. Setting this value to zero * disables the preemption for threads with equal priority and the * round robin becomes cooperative. Note that higher priority * threads can still preempt, the kernel is always preemptive. * * @note Disabling the round robin preemption makes the kernel more compact * and generally faster. */ #if !defined(CH_TIME_QUANTUM) || defined(__DOXYGEN__) #define CH_TIME_QUANTUM 20 #endif
/** * @brief Managed RAM size. * @details Size of the RAM area to be managed by the OS. If set to zero * then the whole available RAM is used. The core memory is made * available to the heap allocator and/or can be used directly through * the simplified core memory allocator. * * @note In order to let the OS manage the whole RAM the linker script must * provide the @p __heap_base__ and @p __heap_end__ symbols. * @note Requires @p CH_USE_MEMCORE. */ #if !defined(CH_MEMCORE_SIZE) || defined(__DOXYGEN__) #define CH_MEMCORE_SIZE 0 #endif
/** * @brief Idle thread automatic spawn suppression. * @details When this option is activated the function @p chSysInit() * does not spawn the idle thread automatically. The application has * then the responsibility to do one of the following: * - Spawn a custom idle thread at priority @p IDLEPRIO. * - Change the main() thread priority to @p IDLEPRIO then enter * an endless loop. In this scenario the @p main() thread acts as * the idle thread. * . * @note Unless an idle thread is spawned the @p main() thread must not * enter a sleep state. */ #if !defined(CH_NO_IDLE_THREAD) || defined(__DOXYGEN__) #define CH_NO_IDLE_THREAD FALSE #endif
/** * @brief OS optimization. * @details If enabled then time efficient rather than space efficient code * is used when two possible implementations exist. * * @note This is not related to the compiler optimization options. * @note The default is @p TRUE. */ #if !defined(CH_OPTIMIZE_SPEED) || defined(__DOXYGEN__) #define CH_OPTIMIZE_SPEED TRUE #endif
/** * @brief Threads registry APIs. * @details If enabled then the registry APIs are included in the kernel. * * @note The default is @p TRUE. */ #if !defined(CH_USE_REGISTRY) || defined(__DOXYGEN__) #define CH_USE_REGISTRY TRUE #endif
/** * @brief Threads synchronization APIs. * @details If enabled then the @p chThdWait() function is included in * the kernel. * * @note The default is @p TRUE. */ #if !defined(CH_USE_WAITEXIT) || defined(__DOXYGEN__) #define CH_USE_WAITEXIT TRUE #endif
/** * @brief Semaphores APIs. * @details If enabled then the Semaphores APIs are included in the kernel. * * @note The default is @p TRUE. */ #if !defined(CH_USE_SEMAPHORES) || defined(__DOXYGEN__) #define CH_USE_SEMAPHORES TRUE #endif
/** * @brief Semaphores queuing mode. * @details If enabled then the threads are enqueued on semaphores by * priority rather than in FIFO order. * * @note The default is @p FALSE. Enable this if you have special requirements. * @note Requires @p CH_USE_SEMAPHORES. */ #if !defined(CH_USE_SEMAPHORES_PRIORITY) || defined(__DOXYGEN__) #define CH_USE_SEMAPHORES_PRIORITY FALSE #endif
/** * @brief Atomic semaphore API. * @details If enabled then the semaphores the @p chSemSignalWait() API * is included in the kernel. * * @note The default is @p TRUE. * @note Requires @p CH_USE_SEMAPHORES. */ #if !defined(CH_USE_SEMSW) || defined(__DOXYGEN__) #define CH_USE_SEMSW TRUE #endif
/** * @brief Mutexes APIs. * @details If enabled then the mutexes APIs are included in the kernel. * * @note The default is @p TRUE. */ #if !defined(CH_USE_MUTEXES) || defined(__DOXYGEN__) #define CH_USE_MUTEXES TRUE #endif
/** * @brief Conditional Variables APIs. * @details If enabled then the conditional variables APIs are included * in the kernel. * * @note The default is @p TRUE. * @note Requires @p CH_USE_MUTEXES. */ #if !defined(CH_USE_CONDVARS) || defined(__DOXYGEN__) #define CH_USE_CONDVARS TRUE #endif
/** * @brief Conditional Variables APIs with timeout. * @details If enabled then the conditional variables APIs with timeout * specification are included in the kernel. * * @note The default is @p TRUE. * @note Requires @p CH_USE_CONDVARS. */ #if !defined(CH_USE_CONDVARS_TIMEOUT) || defined(__DOXYGEN__) #define CH_USE_CONDVARS_TIMEOUT TRUE #endif
/** * @brief Events Flags APIs. * @details If enabled then the event flags APIs are included in the kernel. * * @note The default is @p TRUE. */ #if !defined(CH_USE_EVENTS) || defined(__DOXYGEN__) #define CH_USE_EVENTS TRUE #endif
/** * @brief Events Flags APIs with timeout. * @details If enabled then the events APIs with timeout specification * are included in the kernel. * * @note The default is @p TRUE. * @note Requires @p CH_USE_EVENTS. */ #if !defined(CH_USE_EVENTS_TIMEOUT) || defined(__DOXYGEN__) #define CH_USE_EVENTS_TIMEOUT TRUE #endif
/** * @brief Synchronous Messages APIs. * @details If enabled then the synchronous messages APIs are included * in the kernel. * * @note The default is @p TRUE. */ #if !defined(CH_USE_MESSAGES) || defined(__DOXYGEN__) #define CH_USE_MESSAGES TRUE #endif
/** * @brief Synchronous Messages queuing mode. * @details If enabled then messages are served by priority rather than in * FIFO order. * * @note The default is @p FALSE. Enable this if you have special requirements. * @note Requires @p CH_USE_MESSAGES. */ #if !defined(CH_USE_MESSAGES_PRIORITY) || defined(__DOXYGEN__) #define CH_USE_MESSAGES_PRIORITY FALSE #endif
/** * @brief Mailboxes APIs. * @details If enabled then the asynchronous messages (mailboxes) APIs are * included in the kernel. * * @note The default is @p TRUE. * @note Requires @p CH_USE_SEMAPHORES. */ #if !defined(CH_USE_MAILBOXES) || defined(__DOXYGEN__) #define CH_USE_MAILBOXES TRUE #endif
/** * @brief I/O Queues APIs. * @details If enabled then the I/O queues APIs are included in the kernel. * * @note The default is @p TRUE. */ #if !defined(CH_USE_QUEUES) || defined(__DOXYGEN__) #define CH_USE_QUEUES TRUE #endif
/** * @brief Core Memory Manager APIs. * @details If enabled then the core memory manager APIs are included * in the kernel. * * @note The default is @p TRUE. */ #if !defined(CH_USE_MEMCORE) || defined(__DOXYGEN__) #define CH_USE_MEMCORE TRUE #endif
/** * @brief Heap Allocator APIs. * @details If enabled then the memory heap allocator APIs are included * in the kernel. * * @note The default is @p TRUE. * @note Requires @p CH_USE_MEMCORE and either @p CH_USE_MUTEXES or * @p CH_USE_SEMAPHORES. * @note Mutexes are recommended. */ #if !defined(CH_USE_HEAP) || defined(__DOXYGEN__) #define CH_USE_HEAP TRUE #endif
/** * @brief C-runtime allocator. * @details If enabled the the heap allocator APIs just wrap the C-runtime * @p malloc() and @p free() functions. * * @note The default is @p FALSE. * @note Requires @p CH_USE_HEAP. * @note The C-runtime may or may not require @p CH_USE_MEMCORE, see the * appropriate documentation. */ #if !defined(CH_USE_MALLOC_HEAP) || defined(__DOXYGEN__) #define CH_USE_MALLOC_HEAP FALSE #endif
/** * @brief Memory Pools Allocator APIs. * @details If enabled then the memory pools allocator APIs are included * in the kernel. * * @note The default is @p TRUE. */ #if !defined(CH_USE_MEMPOOLS) || defined(__DOXYGEN__) #define CH_USE_MEMPOOLS TRUE #endif
/** * @brief Dynamic Threads APIs. * @details If enabled then the dynamic threads creation APIs are included * in the kernel. * * @note The default is @p TRUE. * @note Requires @p CH_USE_WAITEXIT. * @note Requires @p CH_USE_HEAP and/or @p CH_USE_MEMPOOLS. */ #if !defined(CH_USE_DYNAMIC) || defined(__DOXYGEN__) #define CH_USE_DYNAMIC TRUE #endif
/** * @brief Debug option, system state check. * @details If enabled the correct call protocol for system APIs is checked * at runtime. * * @note The default is @p FALSE. */ #if !defined(CH_DBG_SYSTEM_STATE_CHECK) || defined(__DOXYGEN__) #define CH_DBG_SYSTEM_STATE_CHECK TRUE #endif
/** * @brief Debug option, parameters checks. * @details If enabled then the checks on the API functions input * parameters are activated. * * @note The default is @p FALSE. */ #if !defined(CH_DBG_ENABLE_CHECKS) || defined(__DOXYGEN__) #define CH_DBG_ENABLE_CHECKS TRUE #endif
/** * @brief Debug option, consistency checks. * @details If enabled then all the assertions in the kernel code are * activated. This includes consistency checks inside the kernel, * runtime anomalies and port-defined checks. * * @note The default is @p FALSE. */ #if !defined(CH_DBG_ENABLE_ASSERTS) || defined(__DOXYGEN__) #define CH_DBG_ENABLE_ASSERTS TRUE #endif
/** * @brief Debug option, trace buffer. * @details If enabled then the context switch circular trace buffer is * activated. * * @note The default is @p FALSE. */ #if !defined(CH_DBG_ENABLE_TRACE) || defined(__DOXYGEN__) #define CH_DBG_ENABLE_TRACE TRUE #endif
/** * @brief Debug option, stack checks. * @details If enabled then a runtime stack check is performed. * * @note The default is @p FALSE. * @note The stack check is performed in a architecture/port dependent way. * It may not be implemented or some ports. * @note The default failure mode is to halt the system with the global * @p panic_msg variable set to @p NULL. */ #if !defined(CH_DBG_ENABLE_STACK_CHECK) || defined(__DOXYGEN__) #define CH_DBG_ENABLE_STACK_CHECK TRUE #endif
/** * @brief Debug option, stacks initialization. * @details If enabled then the threads working area is filled with a byte * value when a thread is created. This can be useful for the * runtime measurement of the used stack. * * @note The default is @p FALSE. */ #if !defined(CH_DBG_FILL_THREADS) || defined(__DOXYGEN__) #define CH_DBG_FILL_THREADS TRUE #endif
/** * @brief Debug option, threads profiling. * @details If enabled then a field is added to the @p Thread structure that * counts the system ticks occurred while executing the thread. * * @note The default is @p TRUE. * @note This debug option is defaulted to TRUE because it is required by * some test cases into the test suite. */ #if !defined(CH_DBG_THREADS_PROFILING) || defined(__DOXYGEN__) #define CH_DBG_THREADS_PROFILING FALSE #endif
/** * @brief Threads descriptor structure extension. * @details User fields added to the end of the @p Thread structure. */ #if !defined(THREAD_EXT_FIELDS) || defined(__DOXYGEN__) #define THREAD_EXT_FIELDS \ /* Add threads custom fields here.*/ #endif
/** * @brief Threads initialization hook. * @details User initialization code added to the @p chThdInit() API. * * @note It is invoked from within @p chThdInit() and implicitly from all * the threads creation APIs. */ #if !defined(THREAD_EXT_INIT_HOOK) || defined(__DOXYGEN__) #define THREAD_EXT_INIT_HOOK(tp) { \ /* Add threads initialization code here.*/ \ } #endif
/** * @brief Threads finalization hook. * @details User finalization code added to the @p chThdExit() API. * * @note It is inserted into lock zone. * @note It is also invoked when the threads simply return in order to * terminate. */ #if !defined(THREAD_EXT_EXIT_HOOK) || defined(__DOXYGEN__) #define THREAD_EXT_EXIT_HOOK(tp) { \ /* Add threads finalization code here.*/ \ } #endif
/** * @brief Context switch hook. * @details This hook is invoked just before switching between threads. */ #if !defined(THREAD_CONTEXT_SWITCH_HOOK) || defined(__DOXYGEN__) #define THREAD_CONTEXT_SWITCH_HOOK(ntp, otp) { \ /* System halt code here.*/ \ } #endif
/** * @brief Idle Loop hook. * @details This hook is continuously invoked by the idle thread loop. */ #if !defined(IDLE_LOOP_HOOK) || defined(__DOXYGEN__) #define IDLE_LOOP_HOOK() { \ /* Idle loop code here.*/ \ } #endif
/** * @brief System tick event hook. * @details This hook is invoked in the system tick handler immediately * after processing the virtual timers queue. */ #if !defined(SYSTEM_TICK_EVENT_HOOK) || defined(__DOXYGEN__) #define SYSTEM_TICK_EVENT_HOOK() { \ /* System tick event code here.*/ \ } #endif
/** * @brief System halt hook. * @details This hook is invoked in case to a system halting error before * the system is halted. */ #if !defined(SYSTEM_HALT_HOOK) || defined(__DOXYGEN__) #define SYSTEM_HALT_HOOK() { \ /* System halt code here.*/ \ } #endif
/*===========================================================================*/ /* Port-specific settings (override port settings defaulted in chcore.h). */ /*===========================================================================*/
#endif /* _CHCONF_H_ */
I changed in STM32L152xB.ld __main_stack_size__ from 0x0400 to 0x0800 and after this to 0x0F00. It didn't help. I also increased __process_stack_size__ from 0x0400 to 0x0800. It also didn't help.
pieter@laptopPW:~$ /home/pieter/software/toolchain/gcc-arm-none-eabi-4_7-2012q4/bin/arm-none-eabi-gcc --version arm-none-eabi-gcc (GNU Tools for ARM Embedded Processors) 4.7.3 20121207 (release) [ARM/embedded-4_7-branch revision 194305] Copyright (C) 2012 Free Software Foundation, Inc. This is free software; see the source for copying conditions. There is NO warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
pieter@laptopPW:~$ /home/pieter/software/toolchain/gcc-arm-none-eabi-4_7-2012q4/bin/arm-none-eabi-gdb --version GNU gdb (GNU Tools for ARM Embedded Processors) 7.4.1.20121207-cvs Copyright (C) 2012 Free Software Foundation, Inc. License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html> This is free software: you are free to change and redistribute it. There is NO WARRANTY, to the extent permitted by law. Type "show copying" and "show warranty" for details. This GDB was configured as "--host=i686-linux-gnu --target=arm-none-eabi". For bug reporting instructions, please see: <http://www.gnu.org/software/gdb/bugs/>.
I tested the STM32L-Discovery demo from the repository but I am unable to reproduce the problem, it just worked. Is it possible something is wrong with your toolchain setup?
