C++ and STM32
Badger
Re: C++ and STM32
Post by Badger »
Thanks for that pointer Giovanni, increasing the main and process stack sizes has fixed it :D
Re: C++ and STM32
Heh, careful, the main() function stack is the "process stack", the "main stack" is the stack for interrupts. It is a bit of a mess but those are the names ARM gave them.
Badger
Re: C++ and STM32
Post by Badger »
Giovanni wrote:Heh, careful, the main() function stack is the "process stack", the "main stack" is the stack for interrupts. It is a bit of a mess but those are the names ARM gave them.
Thanks, that makes sense, I have returned __main_stack_size__ to it's original value!
mobyfab
Has thanked: 21 times
Been thanked: 31 times
Re: C++ and STM32
Post by mobyfab »
Just a heads up,
It works fine on the STM32F4DISCOVERY with some minor changes of course.
I had to increase the stack size as well. Else I cannot create more than 3x128 bytes threads.
Is this the "normal" way of fixing the issue or just a temporary workaround?
Re: C++ and STM32
Temporary workaround, that C++ wrapper needs improvements.
Xamusk
Re: C++ and STM32
Post by Xamusk »
I, for one, use the C API in my C++ projects. It's just too troublesome to access some functions in the correct scopes. For example, imagine that I create some hardware abstraction class and this class needs the delay functions. From where should I call it? Must I have a pointer to the caller thread object just so I can call the delay function? Should the delay function be a static member? If it is static, why not just call the C API?
noether
Re: C++ and STM32
Post by noether »
Xamusk wrote:I, for one, use the C API in my C++ projects. It's just too troublesome to access some functions in the correct scopes. For example, imagine that I create some hardware abstraction class and this class needs the delay functions. From where should I call it? Must I have a pointer to the caller thread object just so I can call the delay function? Should the delay function be a static member? If it is static, why not just call the C API?
Hello Xamusk, I faced the same problems in the past mixing C (RTOS) and C++ (my stuff) in microcontrollers. This FAQ solved to me many of these problems,
http://www.parashift.com/c++-faq-lite/m ... d-cpp.html . I hope this could be useful for you.
Cheers.
noether
Re: C++ and STM32
Post by noether »
I would like to continue this discussion with some issues that I am facing.
I am including Eigen library (http://eigen.tuxfamily.org/index.php?title=Main_Page) just modifying the demo project.
#include "ch.h"
#include "hal.h"
#include "Eigen/Dense"
using namespace Eigen;
   (void)arg;
   int i = 1;
   float valor[2];
   Matrix<float, 3, 3> A, L;
   A = Matrix<float, 3, 3>::Identity(3, 3) +
      Matrix<float, 3, 3>::Constant(1);
   while (TRUE)
      i++;
      L = A.llt().matrixL();
      A(0, 0) += i;
      valor[0] = L(0, 0);
      valor[1] = L(1, 1);
      palSetPad(GPIOD, GPIOD_LED3);       /* Orange.  */
      chThdSleepMilliseconds(500);
      palClearPad(GPIOD, GPIOD_LED3);     /* Orange.  */
int main(void) {
   while (TRUE) {
During the compilation, I do not have any problems if I set the flags to -O2 -DNDEBUG . But once I do not want any optimization for an easy gdb debugging, putting -O0 the linker complains as follows:
Linking build/ch.elf
/home/noether/workspace/tool-chains/arm-none-eabi-4.6.2/lib/gcc/arm-none-eabi/4.6.2/../../../../arm-none-eabi/lib/thumb/cortex-m4/libc.a(lib_a-abort.o): In function `abort':
/home/noether/workspace/tool-chains/summon-arm-toolchain/build/arm-none-eabi/thumb/cortex-m4/newlib/libc/stdlib/../../../../../../../gcc-4.6.2/newlib/libc/stdlib/abort.c:63: undefined reference to `_exit'
/home/noether/workspace/tool-chains/arm-none-eabi-4.6.2/lib/gcc/arm-none-eabi/4.6.2/../../../../arm-none-eabi/lib/thumb/cortex-m4/libc.a(lib_a-signalr.o): In function `_kill_r':
/home/noether/workspace/tool-chains/summon-arm-toolchain/build/arm-none-eabi/thumb/cortex-m4/newlib/libc/reent/../../../../../../../gcc-4.6.2/newlib/libc/reent/signalr.c:61: undefined reference to `_kill'
/home/noether/workspace/tool-chains/arm-none-eabi-4.6.2/lib/gcc/arm-none-eabi/4.6.2/../../../../arm-none-eabi/lib/thumb/cortex-m4/libc.a(lib_a-signalr.o): In function `_getpid_r':
/home/noether/workspace/tool-chains/summon-arm-toolchain/build/arm-none-eabi/thumb/cortex-m4/newlib/libc/reent/../../../../../../../gcc-4.6.2/newlib/libc/reent/signalr.c:96: undefined reference to `_getpid'
collect2: ld returned 1 exit status
make: *** [build/ch.elf] Error 1
Do you know if I can solve this issue with any flag, or adding another external source like syscalls.c?
If I remove the Matrix operations lines, the code compiles without any problems.
Cheers
Re: C++ and STM32
Probably without optimizations unused code is not removed, you have to provide stub implementations of those calls in syscall.c (I would put just a chSysHalt() inside for debug).
noether
Re: C++ and STM32
Post by noether »
Many thanks, it could compiled it. Now let see if the program runs correctly :P
Well, it doesn't xD.
The binary file is close to 130KB (it is 13KB with -O2 -DNDEBUG), and it crashes at the end of vectors.c .
Edit
Already I can get around the problem just with adding some "volatile" for avoiding the optimizations. If you are interested, I can dedicate more time to know what is happening, but I do not know where I have to start.
