GPIOv1/v2 PAL #defines
Hildy
Post by Hildy »
I was getting the FSMC driver from ChibiOS/GFX to work on a Hy-MINI STM32V and while I got the demos going (see http://imgur.com/5VGJBef) I ran into a couple of roadblocks along the way, mainly to do with the PAL differences:
I took SSD1289/gdisp_lld_board_example_fsmc.h and modified it
- what is meant to define STM32F1XX? I ended up defining it in my board.h but I'm not sure of the right place for it to go
- the original code has
palSetBusMode(&busD, PAL_MODE_ALTERNATE(12));
palSetBusMode(&busE, PAL_MODE_ALTERNATE(12));
but for GPIOv1, I needed
palSetBusMode(&busD, PAL_MODE_STM32_ALTERNATE_PUSHPULL);
palSetBusMode(&busE, PAL_MODE_STM32_ALTERNATE_PUSHPULL);
I'm not sure what the accepted way of writing things that are portable across the two GPIO interfaces is.
Re: GPIOv1/v2 PAL #defines
GPIOv1 and GPIOv2 have very different features so there is no commonality except for a subset of the modes (not alternate modes anyway).
GPIOv1 is limited to STM32F1 devices, all newer families use GPIOv2.
In general would be a good idea to keep GPIO configuration out of high level modules and confine it to board.h or the initial setup performed in the main().
trunet
Post by trunet »
sorry to resurrect the thread.
are you successfully made ugfx works on Hy-MINI STM32V? could you share your code?
Wagner
silart
Post by silart »
Hello!
How to choose v2 version of HAL?
I use stm32F107 and this code is not build:
   palSetPadMode(GPIOD, 5, PAL_MODE_ALTERNATE(7));
   palSetPadMode(GPIOD, 6, PAL_MODE_ALTERNATE(7));
STM32F1 is not compatible with all others.
PAL_MODE_ALTERNATE(n) is only available on newer devices. You need to initialize pins using the F1-specific macros (look into ./os/hal/ports/STM32/LLD/GPIOv1/pal_lld.h).
