STM32F3 and Gyroscope Topic is solved
unicondor
Post by unicondor »
Hi to all,
Anyone can send me some example program (or documents) on how to use gyroscope with ChibiOS?
Thanks so muck
Flavio
Re: STM32F3 and Gyroscope
The document would be the gyroscope data sheet and you would interface it using the ChibiOS SPI driver, I don't have a demo for it right now. Maybe somebody else already did something with the Gyro, if so please post here.
unicondor
Post by unicondor »
If i find some example for F1 or F4 and ChibiOS, can i use it for F3?
Yes, almost unmodified as long the gyro is the same device.
MartinP
Post by MartinP »
For the Stm32F3 Discovery You could take the attachment (download/file.php?id=354) in this post (viewtopic.php?f=3&t=1021&p=9621#p9621)as an example
regards
Martin
unicondor
Post by unicondor »
MartinP wrote:For the Stm32F3 Discovery You could take the attachment (download/file.php?id=354) in this post (viewtopic.php?f=3&t=1021&p=9621#p9621)as an example
Thanks a lot... I'm trying the code ;)
RoccoMarco
Has thanked: 83 times
Been thanked: 67 times
Post by RoccoMarco »
Hi Unicondor,
this is main.h of my first application with gyroscope.
    ChibiOS/RT - Copyright (C) 2006-2013 Giovanni Di Sirio
#include "ch.h"
#include "hal.h"
#include "l3gd20.h"
static msg_t message=0;
 * SPI RX and TX buffers.
static uint8_t rxbuf[2];
static uint8_t txbuf[2];
 *Configuration @ max frequency according to MEMS
 *Configuration (9 MHz, CPHA=1, CPOL=1, MSb first, 8bit word).
static const SPIConfig std_spicfg = {
  NULL,
  GPIOE,                                                        /*port of CS  */
  GPIOE_SPI1_CS,                                                /*pin of CS   */
  SPI_CR1_BR_0|SPI_CR1_CPOL|SPI_CR1_CPHA,                       /*CR1 register*/
  SPI_CR2_DS_2 | SPI_CR2_DS_1 | SPI_CR2_DS_0                    /*CR2 register*/
 * This Thread reads the value of WHO_AM_I register of L3GD20
static msg_t SPID1_Thread(void *arg) {
  (void)arg;
  chRegSetThreadName("SPI Drive 1 thread");
  while (TRUE){
    spiAcquireBus(&SPID1);
    spiStart(&SPID1, &std_spicfg);
    spiSelect(&SPID1);
    spiExchange (&SPID1, 2, txbuf, rxbuf);
    spiUnselect(&SPID1);
    spiReleaseBus(&SPID1);
    chThdSleepMilliseconds(10);
  return message;
 * This is a periodic thread that does absolutely nothing except flashing
 * a LED.
static msg_t Blinker_Thread(void *arg) {
  (void)arg;
  chRegSetThreadName("Blinker");
  while (TRUE) {
    palSetPad(GPIOE, GPIOE_LED3_RED);
    chThdSleepMilliseconds(500);
    palClearPad(GPIOE, GPIOE_LED3_RED);
  return message;
 * Declaration of the working areas of threads
static WORKING_AREA(waSPID1_Thread, 256);
static WORKING_AREA(waBlinker_Thread, 128);
 * Application entry point.
int main(void) {
   * System initializations.
   *   RTOS is active.
   * SPI2 I/O pins setup.(It bypasses board.h configurations)
  palSetPadMode(GPIOA, GPIOA_SPI1_SCK ,
                PAL_MODE_ALTERNATE(5)|PAL_STM32_OSPEED_HIGHEST);   /* New SCK */
  palSetPadMode(GPIOA, GPIOA_SPI1_MISO ,
                PAL_MODE_ALTERNATE(5)|PAL_STM32_OSPEED_HIGHEST);   /* New MISO*/
  palSetPadMode(GPIOA, GPIOA_SPI1_MOSI ,
                PAL_MODE_ALTERNATE(5)|PAL_STM32_OSPEED_HIGHEST);   /* New MOSI*/
  palSetPadMode(GPIOE, GPIOE_SPI1_CS ,
                PAL_MODE_OUTPUT_PUSHPULL|PAL_STM32_OSPEED_HIGHEST);/* New CS  */
   *  Transmission buffer setup.
  txbuf[0]=L3GD20_SPI_RW|L3GD20_SPI_AD_3|L3GD20_SPI_AD_2|L3GD20_SPI_AD_1|
      L3GD20_SPI_AD_0;
  txbuf[1]=0x00FF;
   * Starting the transmitter\receiver and the blinker threads.
  chThdCreateStatic(waBlinker_Thread, sizeof(waBlinker_Thread),
                    NORMALPRIO-1, Blinker_Thread, NULL);
  chThdCreateStatic(waSPID1_Thread, sizeof(waSPID1_Thread),
                    NORMALPRIO+1, SPID1_Thread, NULL);
   * Normal main() thread activity, in this demo it does nothing.
  while (TRUE) {
  return 0;
In order to use this code you have to include these files
l3gd20.h
    ChibiOS/RT - Copyright (C) 2006,2007,2008,2009,2010,
                 2011,2012,2013 Giovanni Di Sirio.
    This file is part of ChibiOS/RT.
    ChibiOS/RT is free software; you can redistribute it and/or modify
    it under the terms of the GNU General Public License as published by
    the Free Software Foundation; either version 3 of the License, or
    (at your option) any later version.
    ChibiOS/RT is distributed in the hope that it will be useful,
    but WITHOUT ANY WARRANTY; without even the implied warranty of
    MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
    GNU General Public License for more details.
    You should have received a copy of the GNU General Public License
    along with this program.  If not, see <http://www.gnu.org/licenses/>.
 * @file    l3gd20.h
 * @brief   L3GD20 MEMS interface module through SPI header.
 * @addtogroup l3gd20
#ifndef _L3GD20_H_
#define _L3GD20_H_
/* Driver constants.                                                         */
 * @name    L3GD20 register names
/*                        L3GD20 on board MEMS                                */
/*******************  Bit definition for SPI communication  *******************/
#define  L3GD20_SPI_DI                        ((uint8_t)0xFF)            /*!< AD[7:0] Data input */
#define  L3GD20_SPI_DI_0                      ((uint8_t)0x01)            /*!< bit 0 */
#define  L3GD20_SPI_DI_1                      ((uint8_t)0x02)            /*!< bit 1 */
#define  L3GD20_SPI_DI_2                      ((uint8_t)0x04)            /*!< bit 2 */
#define  L3GD20_SPI_DI_3                      ((uint8_t)0x08)            /*!< bit 3 */
#define  L3GD20_SPI_DI_4                      ((uint8_t)0x10)            /*!< bit 4 */
#define  L3GD20_SPI_DI_5                      ((uint8_t)0x20)            /*!< bit 5 */
#define  L3GD20_SPI_DI_6                      ((uint8_t)0x40)            /*!< bit 6 */
#define  L3GD20_SPI_DI_7                      ((uint8_t)0x80)            /*!< bit 7 */
#define  L3GD20_SPI_AD                        ((uint8_t)0x3F)            /*!< AD[5:0] Address Data */
#define  L3GD20_SPI_AD_0                      ((uint8_t)0x01)            /*!< bit 0 */
#define  L3GD20_SPI_AD_1                      ((uint8_t)0x02)            /*!< bit 1 */
#define  L3GD20_SPI_AD_2                      ((uint8_t)0x04)            /*!< bit 2 */
#define  L3GD20_SPI_AD_3                      ((uint8_t)0x08)            /*!< bit 3 */
#define  L3GD20_SPI_AD_4                      ((uint8_t)0x10)            /*!< bit 4 */
#define  L3GD20_SPI_AD_5                      ((uint8_t)0x20)            /*!< bit 5 */
#define  L3GD20_SPI_MS                        ((uint8_t)0x40)            /*!< Multiple read write */
#define  L3GD20_SPI_RW                        ((uint8_t)0x80)            /*!< Read Write */
/*******************  Bit definition for Registers Addresses*******************/
#define  L3GD20_SPI_AD_WHO_AM_I               ((uint8_t)0x0F)            /*!< WHO I AM */
#define  L3GD20_SPI_AD_CTRL_REG1              ((uint8_t)0x20)            /*!< CONTROL REGISTER 1 */
#define  L3GD20_SPI_AD_CTRL_REG2              ((uint8_t)0x21)            /*!< CONTROL REGISTER 2 */
#define  L3GD20_SPI_AD_CTRL_REG3              ((uint8_t)0x22)            /*!< CONTROL REGISTER 3 */
#define  L3GD20_SPI_AD_CTRL_REG4              ((uint8_t)0x23)            /*!< CONTROL REGISTER 4 */
#define  L3GD20_SPI_AD_CTRL_REG5              ((uint8_t)0x24)            /*!< CONTROL REGISTER 5 */
#define  L3GD20_SPI_AD_REFERENCE              ((uint8_t)0x25)            /*!< REFERENCE/DATACAPTURE */
#define  L3GD20_SPI_AD_OUT_TEMP               ((uint8_t)0x26)            /*!< MEMS ONBOARD TEMP SENSOR */
#define  L3GD20_SPI_AD_STATUS_REG             ((uint8_t)0x27)            /*!< STATUS REGISTER */
#define  L3GD20_SPI_AD_OUT_X_L                ((uint8_t)0x28)            /*!< OUTPUT X-AXIS LOW */
#define  L3GD20_SPI_AD_OUT_X_H                ((uint8_t)0x29)            /*!< OUTPUT X-AXIS HIGH */
#define  L3GD20_SPI_AD_OUT_Y_L                ((uint8_t)0x2A)            /*!< OUTPUT Y-AXIS LOW */
#define  L3GD20_SPI_AD_OUT_Y_H                ((uint8_t)0x2B)            /*!< OUTPUT Y-AXIS HIGH */
#define  L3GD20_SPI_AD_OUT_Z_L                ((uint8_t)0x2C)            /*!< OUTPUT Z-AXIS LOW */
#define  L3GD20_SPI_AD_OUT_Z_H                ((uint8_t)0x2D)            /*!< OUTPUT Z-AXIS HIGH */
#define  L3GD20_SPI_AD_FIFO_CTRL_REG          ((uint8_t)0x2E)            /*!< FIFO CONTROL REGISTER */
#define  L3GD20_SPI_AD_FIFO_SRC_REG           ((uint8_t)0x2F)            /*!< FIFO SRC REGISTER */
#define  L3GD20_SPI_AD_INT1_CFG               ((uint8_t)0x30)            /*!< INTERRUPT1 CONFIG REGISTER */
#define  L3GD20_SPI_AD_INT1_SRC               ((uint8_t)0x31)            /*!< INTERRUPT1 SRC REGISTER */
#define  L3GD20_SPI_AD_INT1_TSH_XH            ((uint8_t)0x32)            /*!< INTERRUPT1 THRESHOLD X-AXIS HIGH */
#define  L3GD20_SPI_AD_INT1_TSH_XL            ((uint8_t)0x33)            /*!< INTERRUPT1 THRESHOLD X-AXIS LOW */
#define  L3GD20_SPI_AD_INT1_TSH_YH            ((uint8_t)0x34)            /*!< INTERRUPT1 THRESHOLD Y-AXIS HIGH */
#define  L3GD20_SPI_AD_INT1_TSH_YL            ((uint8_t)0x35)            /*!< INTERRUPT1 THRESHOLD Y-AXIS LOW */
#define  L3GD20_SPI_AD_INT1_TSH_ZH            ((uint8_t)0x36)            /*!< INTERRUPT1 THRESHOLD Z-AXIS HIGH */
#define  L3GD20_SPI_AD_INT1_TSH_ZL            ((uint8_t)0x37)            /*!< INTERRUPT1 THRESHOLD Z-AXIS LOW */
#define  L3GD20_SPI_AD_INT1_DURATION          ((uint8_t)0x38)            /*!< INTERRUPT1 DURATION */
/* Driver pre-compile time settings.                                         */
/* Derived constants and error checks.                                       */
/* Driver data structures and types.                                         */
/* Driver macros.                                                            */
/* External declarations.                                                    */
#ifdef __cplusplus
extern "C" {
  uint8_t l3gd20ReadRegister(SPIDriver *spip, uint8_t reg);
  int16_t l3gd20ReadAxis (SPIDriver *spip, uint8_t reg);
  void l3gd20WriteRegister(SPIDriver *spip, uint8_t reg, uint8_t value);
#ifdef __cplusplus
#endif /* _L3GD20_H_ */
l3gd20.c
 * @file    l3gd20.c
 * @brief   L3GD20 MEMS interface module through SPI code.
#include "ch.h"
#include "hal.h"
#include "l3gd20.h"
/* Driver local definitions.                                                 */
/* Driver exported variables.                                                */
/* Driver local variables and types.                                         */
static uint8_t txbuf [2];
static uint8_t rxbuf [2];
static uint8_t axis_txbuf[2];
static uint8_t axis_rxbuf[3];
static int16_t axis_value=0;
/* Driver local functions.                                                   */
/* Driver exported functions.                                                */
 * @brief   Reads a generic register value.
 * @pre     The SPI interface must be initialized and the driver started.
 * @param[in] spip      pointer to the SPI interface
 * @param[in] reg       register number
 * @return              register value.
uint8_t l3gd20ReadRegister(SPIDriver *spip, uint8_t reg) {
  txbuf[0] = L3GD20_SPI_RW | reg;
  txbuf[1] = 0xFF;
  spiSelect(spip);
  spiExchange(spip, 2, txbuf, rxbuf);
  spiUnselect(spip);
  return rxbuf[1];
 * @brief   Reads an axis register value.
 * @param[in] reg       low value of an axis register number
 * @return              combined value of low and high axis register.
int16_t l3gd20ReadAxis (SPIDriver *spip, uint8_t reg){
  spiSelect(spip);
  axis_txbuf[0] = L3GD20_SPI_RW | L3GD20_SPI_MS | reg;
  axis_txbuf[1] = 0xFF;
  spiExchange(spip,3, axis_txbuf, axis_rxbuf);
  spiUnselect(spip);
  axis_value=axis_rxbuf[2];
  axis_value=(axis_value << 8) | axis_rxbuf[1];
  return axis_value;
 * @brief   Writes a value into a register.
 * @param[in] value     the value to be written
void l3gd20WriteRegister(SPIDriver *spip, uint8_t reg, uint8_t value) {
  switch (reg) {
    default:
      /* Reserved register must not be written, according to the datasheet
       * this could permanently damage the device.
      chDbgAssert(FALSE, "lg3d20WriteRegister(), #1", "reserved register");
    case L3GD20_SPI_AD_WHO_AM_I:
    case L3GD20_SPI_AD_OUT_TEMP :
    case L3GD20_SPI_AD_STATUS_REG:
    case L3GD20_SPI_AD_OUT_X_L:
    case L3GD20_SPI_AD_OUT_X_H:
    case L3GD20_SPI_AD_OUT_Y_L:
    case L3GD20_SPI_AD_OUT_Y_H:
    case L3GD20_SPI_AD_OUT_Z_L:
    case L3GD20_SPI_AD_OUT_Z_H:
    case L3GD20_SPI_AD_FIFO_SRC_REG:
    case L3GD20_SPI_AD_INT1_SRC:
    /* Read only registers cannot be written, the command is ignored.*/
      return;
    case L3GD20_SPI_AD_CTRL_REG1:
    case L3GD20_SPI_AD_CTRL_REG2:
    case L3GD20_SPI_AD_CTRL_REG3:
    case L3GD20_SPI_AD_CTRL_REG4:
    case L3GD20_SPI_AD_CTRL_REG5:
    case L3GD20_SPI_AD_REFERENCE:
    case L3GD20_SPI_AD_FIFO_CTRL_REG:
    case L3GD20_SPI_AD_INT1_CFG:
    case L3GD20_SPI_AD_INT1_TSH_XH:
    case L3GD20_SPI_AD_INT1_TSH_XL:
    case L3GD20_SPI_AD_INT1_TSH_YH:
    case L3GD20_SPI_AD_INT1_TSH_YL:
    case L3GD20_SPI_AD_INT1_TSH_ZH:
    case L3GD20_SPI_AD_INT1_TSH_ZL:
    case L3GD20_SPI_AD_INT1_DURATION:
      spiSelect(spip);
      txbuf[0] = reg;
      txbuf[1] = value;
      spiSend(spip, 2, txbuf);
      spiUnselect(spip);
I hope this is usefull to you,
best regards
unicondor
Post by unicondor »
Thanks so muck Rocco,
You gave me a nice toy to try :D
I will send you a feedback...
Flavio
RoccoMarco
I have a few toys, a little more complicated, that also involves the Serial over USB Driver. But i'm just a newbie: a lot of bug to do the simplest things. I'll follow this topic. Keep me informed. :mrgreen:
unicondor
Post by unicondor »
I have some error when i try to compile your source code
Description Resource Path Location Type
unknown type name 'SPIConfig' main.c /ARMCM4-STM32F303-DISCOVERY line 36 C/C++ Problem
unknown type name 'SPIDriver' l3gd20.h /ARMCM4-STM32F303-DISCOVERY line 120 C/C++ Problem
unknown type name 'SPIDriver' l3gd20.h /ARMCM4-STM32F303-DISCOVERY line 121 C/C++ Problem
unknown type name 'SPIDriver' l3gd20.h /ARMCM4-STM32F303-DISCOVERY line 119 C/C++ Problem
Where i can find this driver??
Flavio
