Developing for STM324xG-EVAL board
xlh1460
Post by xlh1460 »
I found board support files for ST_STM3220G_EVAL but no demos.
I am actually developing for a STM3241G-EVAL board but the boards are very similar (the PCBs, themselves, are identical)
If anyone has any working ones that they can share, I would appreciate it.
If not, I guess I need to get to work :D
Re: Developing for STM324xG-EVAL board
I have no demos for you - however, you should be able to get demos from different boards working quite quickly since this is the meaning behind the board files.
I couldn't find out what TFT and touchscreen controller is used on that board - if you get those working, we'd be thankful for sharing your drivers and your board files :)
Like Tectu explained you can start from any STM32F4 demo and swap the reference to the board in the Makefile (better start from a simple demo), then you need to fix the small differences such as LED names and port numbers in main.c.
xlh1460
Post by xlh1460 »
I will definitely share anything I do including the support files for the display.
Incidentally, it uses the ILI9325 display chip and the STMPE811 for the touchscreen so I am hopeful that getting those working should be little trouble.
I copied the ST_STM3220G_EVAL directory to ST_STM3241G_EVAL and made the following changes to the board.h file:
$ diff ST_STM3220G_EVAL/board.h ST_STM3241G_EVAL/board.h
27,28c27,28
< #define BOARD_ST_STM3220G_EVAL
< #define BOARD_NAME              "ST STM3220G-EVAL"
> #define BOARD_ST_STM3241G_EVAL
> #define BOARD_NAME              "ST STM3241G-EVAL"
37a38,43
>  * Board voltages.
>  * Required for performance limits calculation.
> #define STM32_VDD                   330
40c46
< #define STM32F2XX
> #define STM32F4XX
Note that I need to add the board voltage as it missing and caused the following compiler error:
Compiling ext.c
In file included from ../../os/hal/include/hal.h:43:0,
                 from ../../os/hal/src/hal.c:37:
../../os/hal/platforms/STM32F4xx/hal_lld.h:924:2: error: #error "invalid VDD voltage specified"
Now I am getting the following errors related to my clock settings:
13:00:05 **** Build of configuration Default for project ARMCM4-STM3241G-EVAL ****
make -j4 all
Compiling hal.c
Compiling adc.c
Compiling can.c
Compiling ext.c
../../os/hal/platforms/STM32F4xx/hal_lld.h:1104:2: error: #error "STM32_PLLCLKIN outside acceptable range (STM32_PLLIN_MIN...STM32_PLLIN_MAX)"
../../os/hal/platforms/STM32F4xx/hal_lld.h:1167:2: error: #error "STM32_PLLVCO outside acceptable range (STM32_PLLVCO_MIN...STM32_PLLVCO_MAX)"
../../os/hal/platforms/STM32F4xx/hal_lld.h:1179:2: error: #error "STM32_PLLCLKOUT outside acceptable range (STM32_PLLOUT_MIN...STM32_PLLOUT_MAX)"
../../os/hal/platforms/STM32F4xx/hal_lld.h:1199:2: error: #error "STM32_SYSCLK above maximum rated frequency (STM32_SYSCLK_MAX)"
../../os/hal/platforms/STM32F4xx/hal_lld.h:1231:2: error: #error "STM32_HCLK exceeding maximum frequency (STM32_SYSCLK_MAX)"
../../os/hal/platforms/STM32F4xx/hal_lld.h:1255:2: error: #error "STM32_PCLK1 exceeding maximum frequency (STM32_PCLK1_MAX)"
../../os/hal/platforms/STM32F4xx/hal_lld.h:1279:2: error: #error "STM32_PCLK2 exceeding maximum frequency (STM32_PCLK2_MAX)"
../../os/hal/platforms/STM32F4xx/hal_lld.h:1324:2: error: #error "STM32_PLLI2SVCO outside acceptable range (STM32_PLLVCO_MIN...STM32_PLLVCO_MAX)"
                 from ../../os/hal/src/can.c:37:
                 from ../../os/hal/src/adc.c:37:
                 from ../../os/hal/src/ext.c:37:
In file included from ../../os/hal/include/adc.h:94:0,
                 from ../../os/hal/include/hal.h:55,
../../os/hal/platforms/STM32F4xx/adc_lld.h:281:2: error: #error "STM32_ADCCLK outside acceptable range (STM32_ADCCLK_MIN...STM32_ADCCLK_MAX)"
make: *** Waiting for unfinished jobs....
make: *** [build/obj/adc.o] Error 1
make: *** [build/obj/can.o] Error 1
make: *** [build/obj/ext.o] Error 1
13:00:08 Build Finished (took 3s.135ms)
The board file has the clocks defined (correctly, I believe) as:
#define STM32_LSECLK 32768
#define STM32_HSECLK 25000000
Your board mounts a different crystal from the original one, you need to setup the clock-related parameters in mcuconf.h in order to have the PLL working in the correct range, this may require some study of the reference manual.
xlh1460
Post by xlh1460 »
I see, I think.
My board has a 25MHz crystal but the mcuconf.h file in my project is one that I "borrowed" from the STM32F4-DISCOVERY demo.
That board has an 8MHz crystal which is why the settings need to be adjusted.
Is that about it?
Correct. you have to operate on:
1) input divider STM32_PLLM_VALUE
2) multiplier STM32_PLLN_VALUE
3) output divider STM32_PLLP_VALUE
Look at figure 13 on the Reference Manual in order to understand all the parameters in mcuconf.h. I think you just need to put "M" at 25 and drive the PLL at 1MHz like the other demos do.
xlh1460
Post by xlh1460 »
You are absolutely right, I just changed the STM32_PLLM_VALUE value to 25 and it compiles fine.
I actually cheated and looked at the mcuconf.h file for an Olimex board with a 25MHz crystal.
I'll have a look at the reference manual too, though since this is pretty important stuff. :)
I am going to take a look now at porting some of the demos that come with the STM32F4 StdPeriph Library.
Thanks again for your support.
xlh1460
Post by xlh1460 »
I have a very simple demo running on my board now which I have attached.
This exercises the 4 LEDs and the 3 pushbuttons available on the board.
ARMCM4-STGM3241-EVAL-demo1.zip
(15.14 KiB) Downloaded 634 times
Good job :)
Moving the thread to the contributions forum.
