I was just looking at SYSTEM_HALT_HOOK, and I can't find any examples of using it. My use case is just to change the mode of a few pins on port_halt, to put a board into a safe state when it halts. It seems like this would be a reasonable use of the hook?
However I can't work out how to use HAL functions from the hook, e.g. palSetPadMode. Is this possible?
I'm running on an STM32F4, custom board, if that makes any difference, thanks.
Use of SYSTEM_HALT_HOOK with HAL
trepidacious
- Been thanked: 1 time
Re: Use of SYSTEM_HALT_HOOK with HAL
The issue is that hal.h is not necessarily included where the macro is placed. The workaround is to just call a function from the hook placed in another module:
extern void myfunc(void);
myfunc();
The module containing myfunc() can include hal.h and use pal functions/macros.
Note that from that hook you should make no assumptions regarding the system state (interrupts enabled or disabled, thread context or ISR context etc).
myfunc();
