3 phase generat using pwm (STM32F407-DISCOVERY )
abhi
Post by abhi »
hi OlivierD
i am facing same kind of problem
did you get 3 phase out put?
am using chibios on STM32F4-Discovery board
trying to generate 3 phase using 6 PWM channel
but i can't get phase shift in each pair of CHx and CHxN (complementary)
if i configure 2 PWMConfig and put some delay in two respective pwmStart()
then i got phase shift between channels respected to 2 different PWMConfig
but don't understand how to get another phase shift . . :?
please help me . . .it's critical situation on my side . .
    #include "ch.h"
    #include "hal.h"
    static PWMConfig pwmcfg1 = {
      10000, // 10Khz PWM clock frequency
      20000, // PWM period 1 second 200,*  50 Hz (20.0 ms) initial frequency
      NULL,  // No callback
        {PWM_COMPLEMENTARY_OUTPUT_ACTIVE_LOW, NULL},
        {PWM_OUTPUT_DISABLED, NULL},
      0,
      0
    static PWMConfig pwmcfg2 = {
      10000, /* 10Khz PWM clock frequency */
      20000, /* PWM period 1 second */
      NULL,  /* No call back */
        {PWM_OUTPUT_ACTIVE_HIGH, NULL},
      0,
      0
    int main(void)
          /*for TIM1/2  PAL_MODE_ALTERNATE(n) = 1 */
         palSetPadMode(GPIOE, 8, PAL_MODE_ALTERNATE(1));//TIM1, channel 1N
         palSetPadMode(GPIOE, 10, PAL_MODE_ALTERNATE(1));//TIM1, channel 2N
         palSetPadMode(GPIOE, 12, PAL_MODE_ALTERNATE(1));//TIM1, channel 3N
      /*  TIM8
       * for TIM8/9/10/11  PAL_MODE_ALTERNATE(n) = 3  */
         palSetPadMode(GPIOC, 6, PAL_MODE_ALTERNATE(3));//TIM8, channel 1
         palSetPadMode(GPIOC, 7, PAL_MODE_ALTERNATE(3));//TIM8, channel 2
         palSetPadMode(GPIOC, 8, PAL_MODE_ALTERNATE(3));//TIM8, channel 3
         pwmStart(&PWMD1, &pwmcfg1);
         pwmEnableChannel(&PWMD1, 0, 10000));
         pwmEnableChannel(&PWMD1, 1, 10000);
         pwmEnableChannel(&PWMD1, 2, 10000);
         chThdSleepMilliseconds(500);
        pwmStart(&PWMD8, &pwmcfg2);
         pwmEnableChannel(&PWMD8, 0, 10000);
         pwmEnableChannel(&PWMD8, 1, 10000);
         pwmEnableChannel(&PWMD8, 2, 10000);
      while (TRUE)
        chThdSleepMilliseconds(5000);
is it possible solution by change in TIMx_CCRx . ..
give me some idea phase shifting
