Raspberry serial port issue
bigjohnson
Post by bigjohnson »
Hello all,
I've compiled Chibios examples for Raspberry pi from
http://www.stevebate.net/chibios-rpi/GettingStarted.html
and when I insert the Chibios test routines in the code the serial port stop work.
The led program run because I see the led flashing.
I try insert the test routines after the shell init and the test run and then the serial port / sehell work ok.
I compiled the examples with gcc version 4.7.3 20121207 (release) [ARM/embedded-4_7-branch revision 194305] (GNU Tools for ARM Embedded Processors)
and ported to ChibiOS_2.6.0 with the same issue.
Someone have a suggestion?
Alberto
NMaas
Re: Raspberry serial port issue
Post by NMaas »
Ok, the problem is about the RPi Firmware.
With version https://github.com/raspberrypi/firmware ... 1989d#boot from 06.01.2013 it does work (Serial Line and everything!)
With the Version 07.01.2013 https://github.com/raspberrypi/firmware ... 211fa/boot [ Enable ZRAM and RFKILL config options. Add mutex around bcm_mailbox_property function. Fix config_hdmi_boost=4 when using hdmi_safe. ] Serial Line broke... So seems like there would be need some adjustments to ChibiOS-RPi to get it working with the latest RPi Firmware...
I will stay with the 06.01.2013 for the time beeing.
NIco
Probably it would be a good idea to inform the port author about this, this is related to the specific port not to ChibiOS in general.
NMaas
Post by NMaas »
@Giovanni
I did post this Snipet as Issue in the GitHub of the Port about a week ago, but sadly he did not respond.
Nico
bigjohnson
today I tried all bootcode.bin and start.elf with or without loader.bin from all the
http://downloads.raspberrypi.org/raspbian/images/
files, and the winner are from
http://downloads.raspberrypi.org/raspbian/images/raspbian-2013-09-27/2013-09-25-wheezy-raspbian.zip
that I think are the same from
http://downloads.raspberrypi.org/raspbian/images/raspbian-2013-10-07/2013-09-25-wheezy-raspbian.zip
the sha digest are the same....
with the boot code combination from this file there are no serial port hang, I tried allot of reboot with no problem.
The Chibios version was:
Kernel:       2.6.0
Compiler:     GCC 4.7.3 20121207 (release) [ARM/embedded-4_7-branch revision 194305]
Architecture: ARM11
Core Variant: ARM1176JZF-S
Port Info:    Pure ARM mode
Platform:     BCM2835
Build time:   Nov 21 2013 - 11:08:28
I hope this info is useful for someone.
Alberto
NMaas
Post by NMaas »
@bigjohnson
Thanks a lot :).
I will check them out!
bigjohnson
Today I tried wit
Kernel:       2.6.1
Architecture: ARM9
Core Variant: ARM9
Platform:     BCM2835
Build time:   Nov 22 2013 - 14:06:23
and the winners are
http://downloads.raspberrypi.org/raspbian/images/2012-07-15-wheezy-raspbian/2012-07-15-wheezy-raspbian.zip
but there are some problems, the serial port don't work 5 times on 10 reboot...
