first of all I want to describe my Problem.
I run two threads, one makes a LED blinking, the other should make a sound through a piezo buzzer (buzzer has no electronic).
Here is my code:
board.h
* MCU type, supported types are defined in ./os/hal/platforms/hal_lld.h.
#define STM32F10X_MD
* IO pins assignments.
#define GPIOA_XBEERESET 4
#define GPIOA_LED1 12
#define GPIOB_LED2 4
#define GPIOB_LED3 5
#define GPIOB_BUZZER 12
#define VAL_GPIOACRL 0xB4B34BB4 /* PA7...PA0 */
#define VAL_GPIOACRH 0x11113333 /* PA15...PA8 */
#define VAL_GPIOAODR 0b0000000000010000
* Port B setup.
* PB5 - Push pull output (LED3). Low 6th Bit set 1
* PB12 - Push pull output (Buzzer)High 5th Bit set 1
#define VAL_GPIOBCRL 0x44111111 /* PB7...PB0 */
#define VAL_GPIOBCRH 0xB4B14444 /* PB15...PB8 */
#define VAL_GPIOBODR 0b0000000000000000
main.c
#include "ch.h"
#include "hal.h"
#include "test.h"
static WORKING_AREA(waThBuzzer, 64);
static WORKING_AREA(waLED1, 64);
static msg_t thBuzzer(void *arg) {
(void)arg;
chRegSetThreadName("Buzzer");
while (TRUE)
palClearPad(GPIOB, GPIOB_BUZZER);
chThdSleepMicroseconds(250);
palSetPad(GPIOB, GPIOB_BUZZER);
return (msg_t)0;
static msg_t thLED1(void *arg) {
(void)arg;
chRegSetThreadName("LED1");
while (TRUE)
palClearPad(GPIOB, GPIOB_LED3);
chThdSleepMilliseconds(25);
palSetPad(GPIOB, GPIOB_LED3);
return (msg_t)0;
* Application entry point.
int main(int argc, char *argv[]) {
* System initializations.
* RTOS is active.
chThdCreateStatic(waThBuzzer, sizeof(waThBuzzer), NORMALPRIO, thBuzzer, NULL);
chThdCreateStatic(waLED1, sizeof(waLED1), NORMALPRIO, thLED1, NULL);
* sleeping in a loop.
while (TRUE) {
chThdSleepMilliseconds(500);
The Problem is, that the Buzzer Pin (PB12) does not output the expected 2 kHz (T = 2x250 us). But it outputs exactly 500 Hz.
The other Thread with the LED is doing what I expect, it pulses the LED with a Frequency of 20 Hz (T = 2x25 ms).
What I am doing wrong?!
Best regards
Stomper
