spiStartExchange() causes port_halt()
Stomper85
Post by Stomper85 »
I am trying to send some strings over SPI but have problems with the port_halt() lock.
I am using an STM32F103 on SPI 1
Here is the code I am using
#include "ch.h"
#include "hal.h"
#include "test.h"
 * Red LED blinker thread, times are in milliseconds.
  (void)arg;
  while (TRUE) {
    palClearPad(GPIOB, GPIOB_LED3);
    chThdSleepMilliseconds(500);
    palSetPad(GPIOB, GPIOB_LED3);
 * SPI configuration structure.
static const SPIConfig spicfg_Acc = {
  NULL,
  /* HW dependent part.*/
  GPIOB,            // Chip Select Port
  GPIOB_CSAcc,      // Chip Select Pin
  (SPI_CR1_MSTR | SPI_CR1_BR_0 |SPI_CR1_BR_2 | SPI_CR1_CPOL ) // MasterMode, Baudratebits
 * Application entry point.
int main(void) {
  // Read/Write + Adress + 2x Dummy Byte
  uint8_t SPIOut1[5] = {0x80, 0x77,0xB3, 0xFF, 0xFF};
  uint8_t SPIOut2[3] = {0xB3, 0xFF, 0xFF};
  uint8_t SPIIn[3] = {0,0,0};
   * System initializations.
   *   RTOS is active.
  spiStart(&SPID1, &spicfg_Acc);
  spiSelect(&SPID1);
  spiStartExchange(&SPID1, 5, SPIOut1, SPIIn);
  //spiStartExchange(&SPID1, 3, SPIOut2, SPIIn);
  spiUnselect(&SPID1);
   * Creates the blinker thread.
   * sleeping in a loop and check the button state.
  while (TRUE) {
I tracked the communication with the logic analyzer and I can see, that all the 5 (3) Bytes are send out by the driver, but the CS line is not been released.
If I halt the debuger, the pointer is in the port_halt() function and the dbg_panic_msg says "spiUnselect(), #1", dbg_isr_cnt "not within ISR" and dbg_lock_cnt "within lock".
But if I uncomment the second spiStartExchange() part, the dbg_panic_msg says "spiStartExchange, #1", so it seems to be a problem with the first spiStartExchange Function as the second is never reached and the CS Line stays low.
What I am doing wrong?!
Best regards
Stomper
Re: spiStartExchange() causes port_halt()
It is very simple, spiStartExchange() is an asynchronous function, it starts the operation and returns immediately, the operation is performed in background using the DMA.
The second spiStartExchange() is invoked while the first is still being executed and the system catches the problem.
You just have to use spiExchange() instead, this is the synchronous version and returns only after the operation is finished.
Stomper85
Post by Stomper85 »
That did the job - thanks!
