Re: MIT/BSD license compatibility
Spym
Has thanked: 2 times
Been thanked: 3 times
Post by Spym »
There is an STM32-based open source/open hardware project that is licensed under MIT open source license.
Is it legal to use ChibiOS in this project as is, or shall the entire project be re-licensed under GPLv3? (ChibiOS source code is not going to be modified if that matters)
The hardware is going to be available commercially, being manufactured in small amounts. Does that alter the legal side of the question?
The same questions are also valid for the case if the project were licensed under the BSD license.
Thanks in advance!
The 3-clause BSD license is compatible with GPL as far I know, please refer to this page: http://www.gnu.org/licenses/license-list.html
Of course you are bound by the GPL but your BSD/MIT modules should be compatible as specified in the above page. If your project is entirely open source then there are no problems, you can use any code from ChibiOS. Of course it is a good practice to keep copyright-clean the software modules, don't mix.
Proprietary hardware is not a problem unless you prevent end user reprogramming it.
