Hey,
I'm new to both chibios and ARM programming, Im wondering about all the steps necessary to run and load the stm32f1 demo code on a stm32f0 board. Right now I have ubuntu with the gcc cross compiler and st-util. I have just compiled the F1 board and targeted it to the f0 discovery which started loading but didn't finish(understandable), and I think I need some guidance as to which files I need to change.
John
Running Demo code on STM32F0 discovery
Re: Running Demo code on STM32F0 discovery
To flash I use the following line
I work with stm32l1, but I thinkthe flashing directive is the same for stm32f0 as well.
I find that I cannot work with openocd reliably, but st-flash works.
st-flash write build/ch.bin 0x8000000I work with stm32l1, but I thinkthe flashing directive is the same for stm32f0 as well.
I think? I just need to point the make file to the f0 appropriate places:include $(CHIBIOS)/boards/ST_STM32VL_DISCOVERY/board.mk
I changed these, but my make is still tossing errors,
I removed the include stm32f10x.h from stm32.h, now Im getting more fundamental issues:
Obviously commenting out that stm32f10x.h from stm32.h was a mistake. Does anyone have a working make/ demo for stmf0 discovery?
include $(CHIBIOS)/os/hal/platforms/STM32F1xx/platform.mk
include $(CHIBIOS)/os/ports/GCC/ARMCMx/STM32F1xx/port.mkI changed these, but my make is still tossing errors,
Compiling test.c
In file included from ../../os/hal/include/hal.h:43:0,
from ../../test/test.c:26:
../../os/hal/platforms/STM32F0xx/hal_lld.h:393:2: error: #error "Using a wrong mcuconf.h file, STM32F0xx_MCUCONF not defined"
In file included from ../../os/hal/platforms/STM32F0xx/hal_lld.h:766:0,
from ../../os/hal/include/hal.h:43,
../../os/hal/platforms/STM32F0xx/stm32_dma.h:183:3: error: unknown type,
../../os/hal/platforms/STM32F0xx/stm32_dma.h:183:3: error: unknown type name 'DMA_Channel_TypeDef'
In file included from ../../os/hal/include/hal.h:53:0,
../../os/hal/include/tm.h:77:3: error: unknown type name 'halrtcnt_t'
../../os/hal/include/tm.h:78:3: error: unknown type name 'halrtcnt_t'
../../os/hal/include/tm.h:79:3: error: unknown type name 'halrtcnt_t'
In file included from ../../os/hal/include/adc.h:94:0,
from ../../os/hal/include/hal.h:55,
../../os/hal/platforms/STM32F0xx/adc_lld.h:286:3: error: unknown type name 'ADC_TypeDef'
In file included from ../../os/hal/include/pwm.h:103:0,
from ../../os/hal/include/hal.h:62,
../../os/hal/platforms/STM32/TIMv1/pwm_lld.h:258:2: error: #error "Invalid IRQ priority assigned to TIM3"
In file included from ../../os/hal/include/serial.h:111:0,
from ../../os/hal/include/hal.h:64,
../../os/hal/platforms/STM32/USARTv2/serial_lld.h:175:2: error: #error "Invalid IRQ priority assigned to USART1"
In file included from ../../os/hal/include/hal.h:64:0,
../../os/hal/include/serial.h:138:3: error: unknown type name 'USART_TypeDef'
In file included from ../../os/hal/include/spi.h:93:0,
from ../../os/hal/include/hal.h:66,
../../os/hal/platforms/STM32/SPIv2/spi_lld.h:222:2: error: #error "Invalid IRQ priority assigned to SPI1"
../../os/hal/platforms/STM32/SPIv2/spi_lld.h:252:2: error: #error "invalid DMA stream associated to SPI1 RX"
../../os/hal/platforms/STM32/SPIv2/spi_lld.h:257:2: error: #error "invalid DMA stream associated to SPI1 TX"
../../os/hal/platforms/STM32/SPIv2/spi_lld.h:363:3: error: unknown type name 'SPI_TypeDef'Obviously commenting out that stm32f10x.h from stm32.h was a mistake. Does anyone have a working make/ demo for stmf0 discovery?
I would suggest to start from either of the directories in the
testhal/STM32F0xx
They have known to work code samples. You will just need to trace appropriate pins to the ones at your board.
Most importantly they have a proper Makefile which compiles, just fill it with needed extras.
testhal/STM32F0xx
The key part is this one:
You need to take the file mcuconf.h from an F0 demo, they are different for each family. I suggest you start from an F0 demo then add what you need.
JohnL wrote:#error "Using a wrong mcuconf.h file, STM32F0xx_MCUCONF not defined"
Thanks! I didn't realize there was other demos in the TEST folders
Ive got code running!
No to figure out how to use chibios! Best regards
John
John
